Looking for a hard drive in the US
Hi, I'm currently in the U.S and I'm interested to buy a HDD. I've already decided about a model.
However my issue is that my home computer is quite old- the motherboard is GIGABYTE 7VRXP and the chipset is KT333, and I'm not certain about whether the HDDs I can find here will plug and work with it.
I know that a Serial ATA HDD won't work for sure. However I've seen a couple of HDDs that are Ultra ATA\100. Will that fit? If not, what should I be looking for?
You can type your answers in Hebrew.
Thanks a lot!
מה השאלה?למה אתה צריך ATA-6?אם הממשק אינו תומך בSATA אז קח IDE רגיל.
כל דיסק קשיח IDE יתאים לך (יותר נכון PATA).
