ישלי סטיק אחד של זיכרון. באיזה DIMM לתקוע אותו?
זה משנה?
מפרט:
Motherboard Name Epox EP-8RDA3(I)/8RDAE(I) (5 PCI, 1 AGP, 3 DDR DIMM, Audio)
-------[ SPD ]---------------------------------------------------------------------------------------------------------
[ DIMM3: [ TRIAL VERSION ] ]
Memory Module Properties:
Module Name [ TRIAL VERSION ]
Serial Number None
Module Size 256 MB (1 rank, 4 banks)
Module Type [ TRIAL VERSION ]
Memory Type DDR SDRAM
Memory Speed PC3200 (200 MHz)
Module Width 64 bit
Module Voltage SSTL 2.5
Error Detection Method None
Refresh Rate Reduced (7.8 us), Self-Refresh
Memory Timings:
@ 200 MHz 3.0-3-3-8 (CL-RCD-RP-RAS)
@ 166 MHz 2.5-3-3-7 (CL-RCD-RP-RAS)
@ 133 MHz 2.0-2-2-6 (CL-RCD-RP-RAS)
Memory Module Features:
Early RAS# Precharge Not Supported
Auto-Precharge Not Supported
Precharge All Not Supported
Write1/Read Burst Not Supported
Buffered Address/Control Inputs Not Supported
Registered Address/Control Inputs Not Supported
On-Card PLL (Clock) Not Supported
Buffered DQMB Inputs Not Supported
Registered DQMB Inputs Not Supported
Differential Clock Input Supported
Redundant Row Address Not Supported
Memory Module Manufacturer:
Company Name Micron Technology, Inc.
Product Information http://www.micron.com/products/category.jsp?path=/DRAM
בעיקרון לא
