Need a Good Graphic Card Gaming Purposes up to 2K
Intel Core 2 Due E6600 FSB1066Mhz 4MB Cashe
Asus P5W-DH Deluxe
2X1GB G.Skill DDR2 PC6400 800Mhz 4-4-4-12
Maxtor Maxline Plus ll 250GB Sata/150 HDD 7200Rpm EX
Plextor CD-RW Premium EX
Nec CD/DVD-RW ND-3551A EX
TEAC 1.44 EX
Termaltake Silent PurePower 560W EX
Termaltake Shurk Full ATX 2x120mm Fan
Logitech MX-1000 Wireless Laser EX
Microsoft Windows XP compatiable EX
Samsung SyncMaster 172T EX
Everythign marked with an "EX" means exist already.
I havn't defined a Graphic Card yet I'll be glad to get your help on this part.
THX.
X1900XT 256MB
THX. ;)
אם אתה מעוניין בשקט הייתי דווקא הולך על הXT עם קירור ZALMAN:
http://www.noacomp.co.il/product.asp?productid=5682
אם לא אפשר כמובן ללכת על הXT 512 ללא הקירור.
[ltr]X1900XT
and for a mother board I would take the P5B Deluxe, if you planning overclocking, which is suggested by the memory. and take the g.skill that ends with HZ (micron D9), the 2GB version is 2GBHZ.[/ltr]
