HWzone
geforce 8 כרטיס directX10 ראשון מגיע לחנויות בנובמבר-פי8 יותר מהר מכרטיסים ישנים
אחרי שתקראו את מה שלמטה, אני בטוח שתסכימו איתי שכל קנייה עכשווית של כרטיס מסך ברמות ה-mid /high עבור ה- gamer הממוצע ,תתברר כטעות גדולה משום שכבר בנובמבר יוצא gforce8 ובינואר יוצאים vista והמשחק המהולל Crysis
שהתחושה בו היא שאתה משחק בסרט הולוודי משום שהוא מנצל את כל מה ש- directX10 יכול לתת.
Crysis A next-generation project by CryTek, makers of the dazzling FPS Far Cry
the geometry shader in Direct X 10 can output results
directly into memory, allowing data to go right back into the
graphics pipeline without going out to the CPU for setup. The
changes will let the GPU accelerate particle effects like
smoke and explosions, which are usually done on the CPU. Games
can also use the geometry shader in combination with texture
arrays to accelerate effects like cube mapping. Games use cube
maps to make an object reflect the world around it. To make an
object like a stainless steel teapot reflect its surroundings,
you have to determine the teapot's surroundings and map it
onto the teapot. Normally, this can take six passes, but a
game can use the geometry shader and a render target array to
create a cube map in one pass."
Direct X 10 is faster than Direct X 9.
Dropping backwards compatibility should do the trick.
"DirectX 10 will increase game performance by as much as six
to eight times. Much of that will be accomplished with smarter
resource management, improving API and driver efficiencies,
and moving more work from the CPU to the GPU. "The entire API
and pipeline have been redesigned from the ground-up to
maximize performance, and minimize CPU and bandwidth
overhead," according to Microsoft. Furthermore, "The idea
behind D3D10 is to maximize what the GPU can do without CPU
interaction, and when the CPU is needed its a fast,
streamlined, pipeline-able operation." Giving the GPU more
efficient ways to write and access data will reduce CPU
overhead costs by keeping more of the work on the video card."
Crysis has Direct X 10 features and it was made on the new and
improved CRYTEK engine.
Crysis will support both DirectX 9 and DirectX 10, which means
that you can run it on a Windows XP PC, as well as an upcoming
Windows Vista PC. You'll get the absolute best graphics with a
Vista machine, but DirectX 9 still will look good. The version
of the game we saw was using a DirectX 9 machine "simulating"
DirectX10 by brute force, and it looked amazing."
While the graphics was unbelievable I was actually more
impressed with the physics in the jungle. I can barely wait to
see the shockwave of a grenade make the trees and leaves
flutter in the blast.. wink
Dx10 cards will be out about November, They will will cost
about the same, some will be more because they are more
powerful and use more expensive memory and production methods
than current cards but only the high end will be like that,
mid range will cost the same or even less.
Dont go all out on a x1900 series from ati or dont get a 7800
series or higher from nvidia right now, you are utterly
wasting your money unless you are rich enough to get another
high end video card when dx10 comes out..
Crysis A next-generation project by CryTek, makers of the dazzling FPS Far Cry. This game is running on the new CryENGINE 2
technology. The game is one of the the first announced to run
on the advanced DirectX 10 architecture.
Published by: Electronic Arts
Developed by: Crytek Studios / Electronic Arts
Genre: First-Person Shooter
Number of Players: 1
Release Date: January 1, 2007
בונא אחי חדשות כאלה מבעסות לי תתחת, במיוחד אחרי שקניתי לא מזמן כרטיס מסך חדש. :kopfpatsch:
פששווו... הולך להיות טוב ב2007 :o
HOLLY S**T כדי להתחיל לחסוך :yelclap: :yelclap: :yelclap::xyxthumbs:
ולפי הכתבה - לא צריך לחסוך כל כך הרבה.
הבעיה זה מי ירצה לקנות את הכרטיס הישן והמעעעעפן שלנו :)
מה המקור של הכתבה?
בקצב כרזה אני עדיין אשאר עם הAXP המזדקן שיש לי במפרט, כי כל פעם שאני מצתכנן שידרוג, זה יוצא כמעט מחשב שלם חדש, וכל איזה חודש יש משהו חדש ומשתלם יותר :kopfpatsch::screwy::P
זה נלקח מכאן , לפי גוגל :
http://www.gamespot.com/features/6143883/p-5.html
(זה העמוד האחרון בכתבה, יש כמה עמודים גם לפני זה, למי שמעוניין לקרוא הכל)
היי שחכתה משהו אנחנו בישראל צריך להתחיל לחסוך
זה שאומרים את כל זה - זה יפה...
אבל בפועל כולם יודעים שיהיו ימבה עיכובים...
כמו מה שהיה עם ה - X1950 פרו...
מה שאומר... קיץ הבא יהיה חם... אני בספק אם יספיקו להוציא לכריסמס שזה בטח הכוונה, אבל כנראה שבאביב זה כבר יהיה בחוץ
הדיון ינעל כי הוא לא מספק שום מידע חדש שמופיע בFAQ או שכבר הוזכר בעבר בדיונים אחרים בפורום.
ננעל.
