פאטץ' 1.4 יצא לבאטלפילד 2!!!
Even though Battlefield 2142 is just around the corner, Electronic Arts has seen fit to patch up its sometimes rather shaky Battlefield 2. The patch is available in a standalone version as well as a 1.3 - 1.4 upgrade. Here's a list of tthe bug fixes in the 1.4 patch. The full readme can be found here.
Bug Fixes
* Fixed the Linux server hangs when trying to load a Special Forces Co-Op map.
* Another attempt at fixing the Red/Blue nametag bug.
* Fixed the missing server info on the map briefing screen.
* Fixed the server browser issues with updating info.
* Fixed the filter by maps size option in the server browser.
* Fixed a low reproducibility crash bug related to the vehicle drop.
* Fixed a crash in Co-op after a player is revived without a kit.
* Fixed a server crash on Linux 32 when trying to rotate maps in Coop Mode.
* Fixed the occasionnal red distance marker appearing on the ground.
* Fixed the bug that caused the player's arms to become invisible when switching weapons.
* Co-Op bot console commands now function on local servers.
* Fixed the excessive damage taken by the Muscle Car.
* Adjusted the minimum number of players to start the round on ranked servers.
The new values for 16, 32 and 64 players are 6, 8 and 8 respectively.
* Re-enabled unlocks on unranked servers.
* Commander options are no longer available whilst commander is dead.
* Fixed bug where a spawn point is shown as selected when it is not if player has spawned in during the preview round.
* Co-Op (Local Server) - Fixed the issue where no other players may join the server if the server host is kicked and banned.
* Ranked Servers now force unlocks.
* Added support for multiple gamemodes in single maplist for mods.
One can only hope that Battlefield 2142 will fare much better in the area of stability on its launch.
אני מוריד עכשיו מפיילפרונט
מה הקטע? יש כבר דיון שני ת'רדים מתחתיך על העדכון
BF2 PATCH 1.4 RELEASED .... FINALLY
:bash: :bash: :bash:
פעם הבאה לפתוח קצת יותר את העיניים
ננעל.
