The Inquirer : " Israeli distributer launches BFG 7950GT
http://www.theinquirer.net/default.aspx?article=34162
Israeli distributor launches Geforce 7950GT
BFG Geforce 7950 GT OC 512MB PCIe
By Fuad Abazovic in the Bosnian wilds: Tuesday 05 September 2006, 15:23
AN ISRAELI distributor decided to launch a 7950 GT card before Nvidia lifted its embargo.
The outfit priced the BFG Geforce 7950 GT OC 512MB PCIe at $505 or 2,000.00 Israeli New Shekels. The BFG is clocked at 565MHz core and 1430MHz memory.
The default non overclocked 7950 GT should be clocked at 550MHz core and 1400MHz memory. Not the greatest overclock that we've seen.
The card has dual Dual-Link DVI-I slots can perform 1170 Million vertices/sec and a memory bandwidth of 45.7 GB/s. The official launch is expected in the middle of the month but if you are in Israel you can preorder one now.
The link is here and try to get there before Nvidia takes it off. To make it more intereesting we did a screen shot for you.
בואו תנסו לנחש על איזה חנות מדובר ... :) ( רמז X1950 .... :) )
בונא הם כותבים כתבה על כל שטות...
הדף כמובן כבר לא זמין והמחיר הוא 2200.
מן הסתם שזה ירד .... :)
