Water Cooling for socket AM2
חכה עוד חודש חודשיים יצאו קירורים ל am2 טובים יותר וגם קירורי מים
בנתיים יש לך תביט טיפון vx ו תנינג'ה שהם קירורי אוויר טובים
הםם טוב, אני משער שאני יכול לחיות עם קרור אןןיר לכמה חודשים.. פשוט ראיתי שהם עכשיו זולים בחבילות אז חשבתי שאקח יחד עם מחשב...
אתה בטוח שעדיף לחכות עם WC?
תודה בכל אופן.
[ltr]for water cooling to be good and by good I mean something that can beat a BT with fan on max, you need at least 2x80mm fans though I'd recommend of 2x120mm or 3x80mm the pump must be at least 400-500 ltr/hr and a reasonable block (swiftech/danger dan/koolance are among of the best)[/ltr]
What do you mean by beat BT? I dont need it to beat best in market with overcloaking etc, I need it to cool teh system well to prolong its life, allow perhaps some 10% overcloking but nothing intensive requiring insane pumps and prices.
Futhermore, by budget has limitations, and this system is priced very well.
All I would need is later by good AM2 block and perhaps block for HDD as well (althuogh I used dual fan cooling for hdd for almost 2 years now, no breakdowns of hdd, 24/7 load :)
כל מערכת תתאים...
אבל לא כל בלוק...
:xyxthumbs:
[ltr]if you're not looking for insane performance, the Thermaltake BigWater 745, should be more than enough.
the radiator part of the kit is insane (3x120mm) but the pump and block are so-so. either way keep in mind that you'll have to wait for the kit to get upgraded to support AM2 or buy and get an AM2 block separately.
but again, if you're not looking into insane performance, why not get the BT VX?[/ltr]
Ok, I am now seriously considering the 745.
What are its advantages? beside better pump? does it compatible to more water blocks etc?
[ltr]advantages? well it doesn't suck...
the radiator is beyond good, it's insane. an overkill if you ask me. 2x120mm is enough if you ask me.
the pump is ahaaaa ok. only 400 LPH, but should be more than enough for your usage.
the block is ok, I guess. it's not swiftech or danger dan, but it's ok. you have to replace the block anyways, so it doesn't matter.
as far as block compatibility goes there's only compatibility with the socket and with hose fitting, which you can get an adapter for.[/ltr]
ok.. well I guess the diffrence worth not getting vga block with kit.
But what is the BT VX? I couldnt find anythign relevant on google...
  • 2 שבועות מאוחר יותר...
Ok, I have waited a while, and the parts should start arriving soon.
Now time to finally order the CPU water block.
I have decided to take one of these two (again for AM2 socket), which one of these 2:
http://www.frozencpu.com/ex-blc-205.html
OR
http://www.frozencpu.com/ex-blc-245.html
The first cost twice more, but I cant find the diffrence anywhere!
To the ebst of my knowledge, both support AM2.
The cooling kit will be TT Bigwater 745
Thanks.
