איתור Serial של וורקרפט 3
פתחתי את זה עם MPQ EDITOR - יש שם בערך 10,000 קבצים, בעלי אותו שם חוץ מהסוף שהוא מספר (מ 00000 עד 10000, משהו כזה).
מה אני אמור לעשות? :nixweiss:
תנסה את זה:
I lost my CD-Key, where can I find it ?
If your game is still installed on your computer, you are in luck.
Get Magickian's CD-Key Grabber. Launch the appropriate game and connect to Battle.net. At the login screen, alt-tab to the desktop and click the Get CD-Key button. If successful, your CD-Key should be displayed in the edit boxes.
Note: You don't have to fully login (by entering your username and password) in
order to get your cd-key.
If your game is not installed, you will have to get a new CD-Key from Blizzard. Read this page for more information.
http://www.thehelper.net/faqs/warcraft.php#I%20lost
ואם הכל אבוד:
This is what Blizzard (
http://www.blizzard.com) says on the subjuect:
The CD-Key is missing or unreadable
To verify ownership, you will need to mail in your CD case. If you do not have your CD case, then you will need to mail in your manual in place of the case.
Mailing Information:
* We suggest you use some form of tracking to make sure your mail gets to Blizzard Entertainment. If we do not receive your package we can not send the replacement.
* For all exchange situations a note is required that explains what happened, what is needed, your full name, your phone number, and a return address.
* A $10 US dollar money order is required for each CD-Key to cover processing costs; no personal check or cash will be accepted. If it has been less than 90 days since you have purchased the game and you include a copy of the sales receipt showing the purchase date within 90 days, the $10 fee will be waived.
* Please allow 2-4 weeks for processing and return shipping.
* Please send all necessary materials to the following address:
CD-Key Replacement
P.O. Box 18979
Irvine, CA 92623
