הדפסת שגיעה על דף (טיפול בנתוני טופס ב-javascript)
הנה הקוד:
<script language="javaScript">
function chackForm()
var msg;
var num = 0;
msg=" " ;
if(document.club.firstname.value.length == 0)
{ msg = msg + "Firstname field is empty\n" ; num = 1; }
if(document.club.firstname.value.length > 15)
{ msg = msg + "First name is too long\n" ; num = 1; }
if(document.club.firstname.value.length == 1)
{ msg = msg + "First name is too short\n" ; num = 1; }
if(document.club.lastname.value.length == 0)
{ msg = msg + "Last name field is empty\n" ; num = 1; }
if(document.club.lastname.value.length > 15)
{ msg = msg + "Last name is too long\n" ; num = 1; }
if(document.club.lastname.value.length == 1)
{ msg = msg + "Last name is too short\n" ; num = 1; }
if(document.club.email.value.length == 0)
{ msg = msg + "eMail field is empty\n" ; num = 1; }
if((document.club.email.value.indexOf("@") == -1)&&(document.club.email.value.length > 0))
{ msg = msg + "shtrudel is missing in the eMail\n" ; num = 1; }
if((document.club.email.value.indexOf(".") == -1)&&(document.club.email.value.length > 0))
{ msg = msg + "Dot is missing in the email\n" ; num = 1; }
if((document.club.email.value.length < 6)&&(document.club.email.value.length > 0))
{ msg = msg + "Email can be at least 6 characters long\n" ; num = 1; }
if(document.club.email.value.length > 25)
{ msg = msg + "Email is too long\n" ; num = 1; }
if((document.club.phonenumber.value.length < 10)&&(document.club.phonenumber.value.length > 0))
{ msg = msg + "phone number too short\n" ; num = 1; }
if(document.club.phonenumber.value.length > 10)
{ msg = msg + "phone number is too long\n" ; num =1; }
if(isNaN(document.club.phonenumber.value))
{ msg = msg + "phone number can containe numbers only!\n" ; num = 1; }
if((document.club.icq.value.length < 5)&&(document.club.icq.value.length > 0))
{ msg = msg + "Icq number too short\n" ; num = 1; }
if(isNaN(document.club.icq.value))
{ msg = msg + "Icq number can containe numbers only!\n" ; num = 1; }
if((document.club.icq.value.length > 12)&&(document.club.icq.value.length > 0))
{ msg = msg + "Icq number is too long\n" ; num = 1; }
if((document.club.year.value < 1890)&&(document.club.year.value >= 0))
{ if(document.club.year.value.length > 0)
{ msg = msg + "Ilogical birth year\n" ; num = 1; }
if(num == 0)
{ msg = "great!" ; }
alert(msg);
</script>
עכשיו מה שאני רוצה שבמקום לעשות alert הוא יחליף טקסט שכבר קיים בדף. או ידפיס את הארור בתוך טבלה.
תודה מראש לכל העוזרים.
אתה צריך להגדיר div עם name ו-id(שיהיו מן הסתם אותו שם נקרא לו kuku)
ואז אתה עושה:
kuku.innerHTML = msg
סליחה טעות
document.getElementById(kuku).innerHTML = msg
לא עובד
כמו גדול
<html>
<head></head>
<body>
<span onClick=document.getElementById(123).innerHTML=("hello")>push</span>
<div id = 123></div>
</body>
</html>
קצת קטנוניות:
<html>
<head><title></title></head>
<body>
<div onClick="document.getElementById('123').innerHTML=('hello'); ">push</div>
<div id="123"></div>
</body>
</html>
האמת היא שזה לא כל כך קטנוני ועדיף שהוא ילמד איך כותבים נכון ולא איך כותבים בשנייה וחצי רק בשביל להגיד "עובד" ;)
