מבקש לדעת באיזו תוכנת קיבוץ עשו את הקובץ הבא: אנשים כנסו זה יכול לעזור לכולם
מגניב
זה באמת 300 מגה מכווצים ב6.5 מגה
אבל הסיומת זה ראר
מה יכול להיות שווינראר עשה את זה?
בפרטים של הקובץ כתוב שזה solid rar archive
Q: I've heard a lot about "Solid" archives. What are they and how can I use
them?
A: It has been well known, for a long time, that one method of increasing
the efficiency of compression, was to copy all the files to be compressed
into a single file, before compressing them. This is called creating a
"Solid" file before compressing. There are programs around which indeed
perform this operation and act as a pre-processor to another archiver.
RAR handles this function internally and invisibly to the user, it
simply "sees" all files together as a single data stream, with th
end result that the final output is significantly smaller than it would
otherwise be. The gain to be had from this type of archive can be
significant and can be 10% - 60% of the size of the original archive.
As with any other gain, there is a price to be paid and that price should
be taken into consideration before creating a "Solid" archive. The best
way to understand if using a solid archive is best for you is to answer
the following questions:
Q: How often are you going to update or modify the archive?
A: Probably never .. Use a solid archive
Rarely .. Use a solid archive
Frequently .. Use a normal archive
Q: Are you using RAR as a packer for an electronic mail system?
A: Yes .. Use a solid archive
IMPORTANT NOTE:
Beware that to extract a file from solid archive RAR scans the whole
archive from the beginning.
If you are using RAR to store archives to some unreliable storage media
(e.g. floppy disks, streamer tapes etc.) you should better use normal,
non solid mode. And you definetely should use the recovery option.
It is impossible to extract files after damaged place in the solid
archive. However in some cases special recovery information helps to
rebuild the damaged archive if it is stored to the archive (the
recovery option was on, the '-rr' switch or 'rr' command applied).
http://www.winrar-rog.de/esupport/faq1.html
ניסתי לעשות קובץ בדחיסה כזו אבל הקובץ יצא בכמה מגהבייט - 98 אחוז מהקובץ המקורי
לעומת זאת הקובץ שפותח התראד הביא הוא 2 אחוז מהקובץ המקורי
אתם יודע איך קובעים את זה?
מגניב
אבל הסיומת זה ראר
כן זה מגניב,במיוחד מתי שמדובר בסירטונים ...מישהו יודע איך אפשר לעשות ככה?
