My video card doesn't receive enough power.
I get a message which says that the video card performance has been decreased
because the video card doesn't receive enough power.
My question is, if i'll keep using my spu for about a month and only then buy
a better psu, will it damage my video card?
u need more powerfull PSU
which 1 is your's?
חיברת בכלל תספק לכרטיס..??
if i didn't, would it work at all?!
i am using hec 400trt
and my video card is
7900gt co
אם לא תחבר, מה הטעם בכרטיס? חיבור החשמל הוא חיוני.
When not recieving enough power, the GPU is underclocked.
I don't think you can damage the card this way.
As long a the card doesn't heat up too much (and I think it won't, do to the lack of power...), the chance of damage is minimal.
גם אם לא חיברת תכרטיס לספק כוח הוא יעבוד...אבל יציג לך הודעות על זה (כמו שהוא מציג לך) ויוריד תתדרים..וכו
לפגוע בכרטיס זה די גבולי..אבל לא רצוי לעבוד ככה בכלל....!!
ok thanks.
Why do the others think i didn't connect my psu :\
I did, but seems like it's just not strong enough.
disconnect anything you don't need from the PSU.
Like a CD drive or a hard drve you can do without.
Right now, your PSU is overloaded and that is very bad.
If the PSU dies, it might take the video card with it.
ok nvm, now it works fine.
