דריוור בטא חדש באתר של NV גירסה 84.12
מישהו ניסה ?
עריכה : עודכן, 3DMARK06 עליה של 100 נק' 3DMARK03 עליה של 150 נק'
NFSMW ניראה שיש עליה קלה שלאיזה 1-2 FPS אבל זה לא ממש מדויק ...
מה?
84.12?
איפה?
קרא את הכותרת שוב...
עדיין לא מבין מאיפו ? :smile1:
מה?
84.12?
איפה?
תכנס לDOWNLOAD DRIVERS ואז תראה קצת למעלה BETA DRIVERS תכנס לשם.
NVIDIA just released a new BETA driver. This driver has release build 84.12 ! The new driver has some long awaited snazzy PureVideo options. The biggest being H.264 support.
H.264 has become one of the most recent buzz words of the video conferencing world. H.264 is a compression algorithm used to transmit video efficiently between endpoints. This algorithm is seen as the replacement for its predecessor, H.263. What is different about H.264 is that it promises to deliver high quality video, H.264 also enables very high quality encoding, producing better results than even MPEG2 and ultimately HDTV levels. Expect next generation hardware platforms to push the high end envelope after conquering the low bandwidth frontier first.
Release Highlights:
Adds support for GeForce 7300 GS and GeForce 7300 LE GPUs.
New NVIDIA PureVideo features and enhancements. Please visit the NVIDIA PureVideo website for more information on PureVideo technology and system requirements.
Support for high definition H.264 hardware decode acceleration on GeForce 6 and 7 series GPUs.
Support for high definition MPEG-2 inverse telecine.
Support for high definition MPEG-2 spatial temporal de-interlacing.
Adds mixed vendor support for NVIDIA SLI.
TV-Out/HD-out support for NVIDIA SLI.
Added support for VSync on Direct3D games when running NVIDIA SLI.
Microsoft® DirectX® 9.0c and OpenGL® 2.0 support
For a full list of fixed and known issues please view the Release Notes
מהאתר http://www.guru3d.com/
אפשר להוריד מכאן
http://downloads.guru3d.com/download.php?det=1336
GURAM
התקנת? יש שינוי בציון הכרטיס לך?
