כרטיס מסך חדש למחשב החלש שלי + תוספת קטנה של זיכרון.
שלום, הנה מפרט המחשב שלי עפ"י sisoft sandra
SiSoftware Sandra
System
Host Name : HOME-EAFAF57C12
User : Naum
Domain : MSHOME
Processor
Model : Intel® Pentium® 4 CPU 2.66GHz
Speed : 2.67GHz
Performance Rating : PR2940 (estimated)
Cores per Processor : 1 Unit(s)
Threads per Core : 1 Unit(s)
Internal Data Cache : 16kB Synchronous, Write-Thru, 8-way set, 64 byte line size
L2 On-board Cache : 1MB ECC Synchronous, ATC, 8-way set, 64 byte line size, 2 lines per sector
Mainboard
Bus(es) : ISA AGP PCI IMB USB i2c/SMBus
MP Support : 1 Processor(s)
MP APIC : Yes
System BIOS : Phoenix Technologies, LTD 6.00 PG
System : SiS Technology Inc. SiS661FX + SiS964
Mainboard : http://www.abit.com.tw SG-80 (SiS 661FX-964)
Total Memory : 511MB DDR-SDRAM
Chipset 1
Model : Abit Computer Corp SiS661FX CPU to PCI Bridge
Front Side Bus Speed : 4x 134MHz (536MHz data rate)
Total Memory : 512MB DDR-SDRAM
Video System
Monitor/Panel : Default Monitor
Adapter : NVIDIA GeForce FX 5200
Imaging Device : VGA USB Camera
Physical Storage Devices
Removable Drive : Floppy disk drive
Hard Disk : WDC WD800BB-00JHC0 (75GB)
CD-ROM/DVD : SONY DVD RW DW-Q30A (CD 48X Rd, 48X Wr) (DVD 6X Rd, 6X Wr)
CD-ROM/DVD : Generic DVD-ROM SCSI CdRom Device (CD 32X Rd) (DVD 4X Rd)
Logical Storage Devices
1.44MB 3.5" (A : N/A
Hard Disk (C : 37GB (9.9GB, 26% Free Space) (NTFS)
CD-ROM/DVD (D : N/A
New volume (E : 37GB (10GB, 27% Free Space) (NTFS)
CD-ROM/DVD (F : N/A
Peripherals
Serial/Parallel Port(s) : 1 COM / 1 LPT
USB Controller/Hub : SiS 7001 PCI to USB Open Host Controller
USB Controller/Hub : SiS PCI to USB Enhanced Host Controller
USB Controller/Hub : USB Root Hub
USB Controller/Hub : USB Composite Device
Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Mouse : PS/2 Compatible Mouse
MultiMedia Device(s)
Device : Realtek AC'97 Audio
Printers and Faxes
Model : HP DeskJet 720C
Power Management
AC Line Status : On-Line
Operating System(s)
Windows System : Microsoft Windows XP/2002 Professional (Win32 x86) 5.01.2600 (Service Pack 2)
Network Services
Adapter : SiS 900-Based PCI Fast Ethernet Adapter
Adapter : Realtek RTL8139 Family PCI Fast Ethernet NIC
Performance Tips
Warning 100 : Large memory sizes should be made of Registered/Buffered memory.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
אני מעוניין בלקנות זכרונות חדשים וכרטיס מסך חדש.
קודם כל, אני ממש לא מבין בחומרה, אולי בקושי. אני יודע לחבר הכל, אבל לא יודע מה הולך עם מה ואיך. מאחר ויש לי את המחשב המעפן הזה אף פעם לא התעניינתי.
אני מעוניין בלהוסיף עוד 512 DDR של אותו זיכרון שיש לי כרגע.
הכרטיס מסך חשבתי על
?X800GT 256MB, DDRIII, PCI-E
שעולה 890 שקל ב KSP.
אולי יש בעיות תאימות, אולי בעיות אחרות... כמו שעם המפרט הנוכחי הכרטיס לא יצליח לממש את עצמו בצורה הכי טובה.. וכ"ו.
תקציב מקסימלי 1300 ש"ח - וזה לא אומר שצריך להגיע לשם :)
אשמח לעזרה. תודה!
עריכה:
Cpu-Z:
הX800GT שציינת כאן לא יפעל על המערכת שלך.
הייתי ממליץ על 6600GT AGP.
הלוח אם שלך תומך בזיכרון DDR הראשון
בנוסף הלוח אם שלך תומך ב AGP ולא PCIE
ככה שמומלץ ללכת על כרטיס מסך 6800 point of view בפנדה אני חושב עולה 800
אגב.... המחשב שלך סבבה לגמרי. אין לך מה להתבאס :xyxthumbs:
פנדה מעולים, הזמנתי אצלם Radeon 9500 PRO (שכרגע במחשב במשטרה - עדיף שלא תדע)
בכל מקרה, אשמח לקישור, ואם אפשר גם הפניה לאיזה זכרון אני צריך.. מצידי להזמין הכל מפנדה.
ואגב, המחשב באמת לא כ"כ רע, במקור הוא היה מכוון לסרטים. אבל עכשיו שאני משחק World Of Warcraft זה פשוט בלתי נסבל.
אתה צריך פשוט זיכרון DDR400 רגיל שעובד על CL3 (עדיף שלא יהיה התנגשות עם הבקר זיכרון או הכרטיס שכבר קיים)
ואם תעלה תמונה שוב עם CPU-Z של SPD שם יהיה יותר נחמד לראות איזה זיכרון יש לך במחשב בדיוק ...
הזיכרון שתקנה 400MHZ לא יעבוד על 400 אלא על 333MHZ או כמו הזיכרון שכבר קיים במחשב ...
במידה והכרטיס 6800 של POV שציינו קיים במלאי אל תהסס לקחת אותו למחשב שלך
במידה ולא קיים יותר (ולא יהיה גם בעתיד זה בטוח)
אז יש לך או לקחת X1600PRO של ATI ל AGP כמובן... או לחכות ל 6800GS במחיר טוב
6600GT אני לא כל כך חושב שכדאי לאור זאת שיש את X1600PRO שהוא טוב יותר ...
ולסחוב עם המחשב הזה עד יומו האחרון כי המחשב שלך יחסית טוב ויחזיק אותך לתקופה של שנה שנתיים ב"ה ...
המחשב שלך די סבבה ואין לך מה להתבאס,המחשב שלך טוב מאוד.
ומכאן לנושא הדיון.
חבר שלי רצה לקנות את הVOP 6800 אבל הוא התקשר לפנדה והם אמרו שהיבואן מפסיק לייבא כרטיסים שלהם לארץ ובקרוב הם יודעו כך באתר אבל לא ניתן לקנות כרטיסים של POV.
ועכשיו להמלצה לכרטיס.
זה קישור ל6600GT AGP:
http://www.pandas.co.il/product_info.php?cPath=609_273_95_1012&products_id=8691
וזכרונות תקנה DDR400 עם CL3 בלבד!
