מי שרוצה לשנות בדמו של קומנדוס את הרזולוציה - פיתרון
Open the config folder in your commandos directory, then open the file JuegoVer.cfg (with something like wordpad) and change these lines:
.resolution ( 1280.000000 1024.000000 )
.resolutionNTSC ( 1280.000000 1024.000000 )
Those are originally set to 800 and 600, change them to your desired resolution. While you are at it you can change these as well:
.bMarketingWhenExit 0
.bLoadSaveEnable 1
.bMenusExtrasActivo 1
Their use is quite self explanatory.
Additionally if you want to another difficulty make sure you have bLoadSaveEnable set to 1. That way you can create a profile (this way your settings in the options menu will be stored in a profile as well). If you want an extra difficulty level go to "my documents" there's a folder called CSF_data, open profile with wordpad then change this line COMMANDO_DIF or smth by setting it to 1
