פורסם 2006 בפברואר 2420 שנים כן, ב-Patch הזה יש תמיכה ב Dual-core ו-Hyper-threading.http://www.idsoftware.com/documents/readme_update_11beta.htm
פורסם 2006 בפברואר 2420 שנים ?and what do u think SMP is? SuperMegaPhunzor"How to enable Hyper-Threading Technology in the game:By DEFAULT, the symmetric multiprocessing (SMP)-based acceleration (which is the feature that enables the performance increase) is DISABLED. If you have a system with multiple CPUs or cores, please follow the directions below.From the Quake 4 Main Menu:1. Click "Settings".2. Click "System".3. Click "Advanced Options".4. Set "Multiple CPU/Core" to "Yes". (You will be prompted that your changes will not take effect until next time the game is launched.)5. Click "Back".6. Click "EXIT" and relaunch the game to initialize the change. Quake 4 will detect the number of processors in your system and prevent you from mistakenly activating this option. If you feel that your system has the necessary hardware to run the SMP optimization, please consult your hardware manufacturer's guides or manuals for instructions on how to enable the multi-processor or dual core feature on your system."
