פורסם 2006 בפברואר 1420 שנים טוב יש לי את זה- This mod will completely change every single campaign level into a Halo 2 look-alike. This of course meaning the missions now have h2 weapons (no duel wields yet tho...) and that the missions are spilt between the Arbiter and MC. For a more detailed list of what the conversion mod does, see the "Full Details" section _________________ Installation ------------------------ You're going to need HMS and HMT for this so go download them if you dont have them. The conversion is intended to be installed onto non-modded campaign maps, however they sometimes will work with modded ones. (See FAQ to see if your maps will let the conversion install correctly) Now I also suggesting backing up all your maps now with HMS just in case you ever want to get rid of this Conversion. Now after you've backed up your maps, do the following: 1. Place all the PPF's located in this mod into your HMS/PPF folder. The HMS folder should be found in the same place you installed Halo if you installed it right. 2. Open the PPF module of HMS 3. Apply the following PPF's to the maps defined below: halomoda10.ppf ---> a10.map halomoda30.ppf ---> a30.map halomoda50.ppf ---> a50.map halomodb30.ppf ---> b30.map halomodb40.ppf ---> b40.map halomodc10.ppf ---> c10.map halomodc20.ppf ---> c20.map halomodc40.ppf ---> c40.map halomodd20.ppf ---> d20.map halomodd40.ppf ---> d40.map Halo2HUDVersion1.ppf ---> bitmaps.map Now to install the textures that couldn't be placed in a PPF, close HMS and open HMT then open any map. Then inject the textures defined below over the defined texture (if a texture isnt contained in the Bitmaps tag of the map ur in, switch to a different one that has it. Most of these are found in b40.map): tron_warthog1.dds.dds ---> vehicles\warthog\bitmaps\warthog tron_warthog chaingun1.dds.dds ---> vehicles\warthog\bitmaps\warthog chaingun tron_warthog tires1.dds.dds ---> vehicles\warthog\bitmaps\warthog tires banshee-tron.dds.dds ---> vehicles\banshee\bitmaps\banshee ghost1.dds.1.dds ---> vehicles\ghost\bitmaps\ghost scorpmetroid.dds ---> vehicles\scorpion\bitmaps\scorpion_body cubemap banshee1.dds.1.dds ---> vehicles\banshee\bitmaps\cubemap banshee cel monitor base.dds ---> characters\monitor\bitmaps\monitor_base ring clear afternoon1.dds.1.dds ---> sky\ring\ring clear afternoon cyborg.dds ---> characters\cyborg\bitmaps\cyborg cyborgarms.dds characters\cyborg\fp\bitmaps\cyborg hands halo_logo1.dds.1.dds ---> ui\shell\main_menu\halo_logo Now the follwing DDS you shoudn't install IF you wish to have MC in the Halo2 Skin: MC-Red.dds ---> characters\cyborg\bitmaps\cyborg Now you've competly installed the conversion. Go play it now and enjoy ומה זה לעזזל התוכנות האלה ואיפה אני מסיג אותם(במיקרה שזה חוקי) בתודה STONE
