עזרה עם JS וטופס
יש לי בעיה עם JS וטופס אשמח אם מישהו יעזור לי:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "[url]http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">[/url]
<html xmlns="[url]http://www.w3.org/1999/xhtml">[/url]
<head>
<meta http-equiv="Content-Type" content="text/html; charset=windows-1255" />
<title>Untitled Document</title>
</head>
<body>
<script language="javascript">
function loc(loca) {
document.write("X");
var chr = split(loca);
for (i=0;i<chr.length;i++) {
if (chr[i]=="p" && chr[i+1] == "r") {
chr[i] = "l";
chr[++i] = "2";
break;
window.location.href=chr;
</script>
<form OnSumbit = 'loc(window.location);' action="">
<label>
<input type="submit" name="Submit" value="הבא"/>
</label>
</form>
</body>
</html>
בתודה מראש
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
</head>
<body>
if (chr=="p" && chr[i+1] == "r") {
chr = "l";
chr[++i] = "2";
break;
</script>
<input type="submit" name="Submit" value="הבא" onclick='loc(window.location);'/>
</body>
</html>
כבר התקדמות אך משום מה FF כותב לי ב-JS CONSOLSE:
Error: [JavaScript Error: "split is not defined" line: 11]
אולי התכוונת לכתוב אז
loca.split() instead of what you wrote.. it's good to learn the basics of a language before using it
עשיתי ככה ועדיין לא עובד: :-\
<head>
</head>
<body>
var chr = loca.split;
if (chr[i]=="p" && chr[i+1]=="r") {
chr[i] = "l";
chr[++i] = "2";
break;
window.location = chr;
</script>
</body>
</html>
FF כותב "chr has no properties".
take a closer look... i said loca.split() which is a method, you decided to write loca.split which is a datamember/property (which ofcourse doesnt exist)
ניסיתי:
<head>
</head>
<body>
var chr = loca.split();
chr[i] = "l";
chr[++i] = "2";
break;
</script>
</body>
</html>
FF כעת אומר:
"loca.split is not a functin".
אז נסה
loca.toString().split() and that should work
מוזר זה לא עובד לי אלא רק loca.toString... :P
עכשיו דבר מוזר עוד יותר שקורה לי הוא ככה:
var chr = loca.toString();
for (i=0;i<45;i++) {
alert("H");
chr[i] = "1";
chr[i+1] = "2";
break;
document.write(chr);
ההודעה h נכתבת אבל המחרוזת לא משתנה. :pissed:
split עובד, אבל זה רק בתנאי שיש לך מושג מה הוא עושה ומה הפרמטרים שלו....
בלי לבדוק, אני יכול להניח שזה לא עובד כי אתה עושה משהו כמו i מ 0 עד 45 במקום i מ 0 עד chr.length פחות 2 (כשאתה ניגש לתא במערך שלא קיים, ה JS יזרוק EXCEPTION ויפסיק נראה לי.
לא עובד: בכלל:
var chr = loca.toString().split();
alert("H");
chr[i] = "1";
chr[i+1] = "2";
break;
</script>
רק מדפיס את הכתובת הנוכחית:
alert("H");
chr[i] = "1";
chr[i+1] = "2";
break;
</script>
יש לי רעיון מ-ע-ו-ל-ה, תסביר בדיוק מה אתה צריך !
