מה הפאטץ הכי חדש של BF2?
כי אני מנסה לשחק בסרברי הישראלים [Gamers וMgamers] וזה אומר שיש לי גירסא ישנה יותר,והורדתי את הגירסא הכי חדשה... :nixweiss:
הם כנראה עוד לא עידכנו לגירסא החדשה
כן אבל מה הגירסא הכי חדשה? לי יש,bf2 patch 103.
אצלי במישחק כתוב: 1.1.2551,ואצלהם כתוב 1.1.2554-356.0 :nixweiss:
אה כי כבר יש 1.12...
אוף! :bash: צריך להתקין את המישחק מחדש? [לעשות UNINSTALL ואז INSTALL שוב ואז פאטץ??]
לא.
מה לא? ???
פשוט תוריד את ה-Patch ותתקין אותו... זהו
ד"א כבר 1.2 בפיתוח, וה CHANGELOG נראה בהחלט משמח :)
- Helicopter now carry 8 missiles rather than 14
- TV-Guided missile now have a shorter range
- Hit points on all air vehicles has been reduced
- AA missile lock has been improved
- Support kits have had their primary weapons adjusted for accuracy
- Sniper kits have had their primary weapons adjusted for accuracy
- Anti-Tank kits have had their primary weapons adjusted for accuracy
- "Dolphin Diving" is no longer possible
- Players can no longer jump and shoot at the same time
- "Prone Spamming" is now fixed
- "Sprint exploit" is now fixed
- The Sa80 weapon has been improved
- The G3A3 weapon has been improved
- Reload while sprinting has been enabled
- Chinese and MEC APCs can now shoot through penetrable materials
- Damage decreased for the M134
- Medic defibrillator paddles have been adjusted. They now reload while not in use.
We'll be announcing further additions to this list, but that will have to wait until the next update. This is NOT the complete list of items we are working on. As we have more items go through testing and we are sure of a change we will update you.
http://www.gotfrag.com/bf/story/30633/
