אני צריך שתעזרו לי לנתח Traceroute לשרתים של WoW
בזמן האחרון יש לי פינגאים נוראים ב- WoW, אז שלחתי אימייל לתמיכה הטכנית שלהם עם ה- Traceroute והם טוענים שהבעיה היא ב- ISP ולא אצלם למרות שהרבה אנשים בזמן הזה התלוננו אצלם.
מה אתם חושבים? זה בעיה אצל ברק או אצלם?
Tracing route to eu.logon.worldofwarcraft.com [80.239.178.111]
over a maximum of 30 hops:
1 27 ms 19 ms 18 ms barak-1-lns-8.barak.net.il [62.90.133.68]
2 28 ms 19 ms 28 ms 62.90.133.78
3 20 ms 19 ms 29 ms 62.90.133.129
4 22 ms 19 ms 19 ms 212.150.232.125
5 119 ms 119 ms 119 ms 212.150.232.250
6 194 ms 219 ms 199 ms ldn-tch-i1-link.telia.net [213.248.100.25]
7 94 ms 99 ms 99 ms ldn-b1-geth4-0.telia.net [213.248.100.217]
8 95 ms 99 ms 99 ms ldn-bb1-pos1-1-0.telia.net [213.248.64.97]
9 107 ms 109 ms 109 ms prs-bb1-pos6-0-0.telia.net [213.248.64.9]
10 106 ms 99 ms 99 ms prs-b2-pos15-0.telia.net [213.248.65.222]
11 105 ms 100 ms 109 ms prs-tc-ks51-geth0-1.telia.net [213.248.70.22]
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
הנה מה שהוא כתב לי שם -
Hello,
Thank you for sending us the information.
After looking through the trace route I have noticed that the latency occurs between hops 4 and 5:
As this occurs before the data reaches our own servers, you will need to contact your ISP as to the reason why the route is getting delayed at this point which is causing latency in the game.
If you have any further questions or problems don't hesitate to contact us again.
תודה!
דרור,
הבן אדם צודק. הפינגים לא מגיעים אפילו לשרת של WOW אז איך הוא יכול להיות אחראי לזה?
הסיפור הוא עם הראוטרים של .telia.net
ואני לא יודע אם ברק אחראים לזה או לא אבל אולי כדאי לדווח להם על הבעיה והם יכולים לנסות לנתב דרך מקום אחר (אולי)
טליה היא חברה שמספקת לברק קווים בינלאומיים.
