I have problams with my computer
I just wanna say i'm sorry for not writing in hebrew but that is probably caused by the problams my computer is having...
Your answers can be written in hebrew since I have no problams readind it...
I just finished putting my new rig together yesterday. stuff included:
- AMD Dual Core X2 4200+ w/TT Sonic Tower
- DFI LanParty NF4 Ultra-D
- G.Skill LA 2*512MB
- eVGA GeForce 7800GTX KO ACS3
- TT PurePower 480W
At first, I just set everything as it should be and started installing the windows. At some point, it just stopped suddenly and gave this blue error screen. I was thinking maybe it was the memory or the dimms of the mobo but when I pulled out the 2 fans of my sonic tower, the installation was complete. Even though the computer should be working properly now, I still have this feeling as if it's working slower then it should. I think the problam is the power supplier but i don't wanna buy a new one and then find out that it wasn't the problam...
In addition, my cd-rom stopped working proparly once the windows finished installing and now I can't add hebrew
Do you have any idea what the problam might be?
Thanks.
your windows is 64 bit ?t
Ok man.
I can think of several causes :
1. your temperatures are reaching high
2. your powersupply rails aren't balanced
3. your cpu isn't clocked at default.
4. you are just experiencing the cool-n-quiet feature, which underclocks your amd when it's idle.
You need to download an inspection tool like everest - http://www.lavalys.com/products.php?lang=en
download home edition.
after your computer has ran for at least a few hours, run this program click report, make sure only computer-sensor is checked
now copy and paste the sensor part of the generated html (should have all temperatures + rail voltages)
לדעתי זה שייך לפורום תמיכה טכנית
מועבר
I don't think the problasm has anything to do with my computer being oc'ed (even though it's not...) because the problam first occured while I was installing the windows meaning I didn't even have a chance to oc my computer even if I wanted to.
The temps of the cpu are fine (31-33 degrees on idle) so I don't think the problam is coming from there...
So again, in my opinion the problam is either the HDD or the PSU.
