היום קיבלתי מסך כחול (פעמיים) בעת משחק ב- battlefield 2
באופן מוזר המשחק נתקע (3 פעמים היום). פעמיים קיבלתי מסך כחול ואז זה עשה רסטרט, ופעם אחת זה לא הראה מסך כחול אלא אתחל מייד..
בדקתי את קובץ המינידאמפ והנה מה שזה אומר:
Microsoft ® Windows Debugger Version 6.5.0003.7
Copyright © Microsoft Corporation. All rights reserved.
Loading Dump File [C:\WINDOWS\Minidump\Mini103105-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Kernel base = 0x804d7000 PsLoadedModuleList = 0x805531a0
Debug session time: Mon Oct 31 16:04:37.656 2005 (GMT+2)
System Uptime: 0 days 1:55:08.321
Loading Kernel Symbols
Loading unloaded module list
Loading User Symbols
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 24, {1902fe, f7a13a58, f7a13754, f731a126}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
Unable to load image Ntfs.sys, Win32 error 2
*** WARNING: Unable to verify timestamp for Ntfs.sys
*** ERROR: Module load completed but symbols could not be loaded for Ntfs.sys
Probably caused by : Ntfs.sys ( Ntfs+28126 )
Followup: MachineOwner
מה הבעיה כאן (משהו עם ההרד דיסק? ), ואיך ניתן לפתור אותה?
תודה.
