enabling DMA
where can i check if DMA is enable and if not than enable DMA for cdrom / cd-rw / h.disk ?
(win2k/winxp)
10x
Right clicl "My copmuter" go to Properties -> Hardware -> Device Manager
open the IDE ATA/ATAPI controllers, go inside Primary IDE channel,
and than look at the Advanced Settings, you should it!
10x
how can i see if DMA is enabled also for my cdrom ?
the same way
but choose the right ide channel !
