framebuf error
שלום
ניסיתי להתקין xp מחדש במחשב אבל אני מקבל הודעת שגיאה וההתקנה לא מתבצעת
The error was caused by file: framebuf
Device driver got stuck in an infinite loop. This usually indicates a
problem with the device itself or with the device driver programming the
hardware incorrectly.
Technical Information: STOP: 0x000000EA (0x80A45DA8, 0x80A82D40,
0x80B1DED8, 0x00000001)
framebuf
Beginning Dump of Physical Memory...
האם מישהו יודע לפתור בעיה זו?
http://www.cybertechhelp.com/forums/archive/index.php/t-58394.html
i had thsi sam problom yesterday . I removed all my pci cards and reinstalled and it worked perfectly and then i put the cards back in when it was done.
http://www.google.com/search?q=framebuf+error&sourceid=mozilla-search&start=0&start=0&ie=utf-8&oe=utf-8&client=firefox-a&rls=org.mozilla:en-US:official
