האם יש אלוהים?
האם יש אלוהים? 443 הצבעות
  1. 1. האם יש אלוהים?
    • כן
      44%
    • לא
      45%
    • יש משהו ,אבל זה לא אלוהים
      10%
תגידו, אנקודר כבר שם את התמונה של "להתווכח באינטרנט זה כמו לנצח באולימפיידת המיוחדים..."?
  • תגובות 372
  • צפיות 31k
לא, אבל מישהו אחר שם את זה. :smile1:
א, טוב, זה גם בסדר...
here you go read this little story
This has a thought provoking message no matter how you believe. Does evil exist?
The university professor challenged his students with this question. Did God create everything that exists?
A student bravely replied yes, he did!"
"God created everything?" The professor asked.
"Yes, sir," the student replied.
The professor answered, "If God created everything, then God created evil since evil exists, and according to the principal that our works define who we are then God is evil."
The student became quiet before such an answer.
The professor was quite pleased with himself and boasted to the students that he had proven once more that the Christian faith was a myth.
Another student raised his hand and said, "Can I ask you a question professor?" "Of course", replied the professor. The student stood up and asked, "Professor, does cold exist?"
"What kind of question is this? Of course it exists. Have you never been cold?" The students snickered at the young man's question.
The young man replied, "In fact sir, cold does not exist. According to the laws of physics, what we consider cold is in reality the absence of heat. Everybody and every object is susceptible to study when it has or transmits energy, and heat is what makes a body or matter have or transmit energy. Absolute zero (- 460 degrees F) is the total absence of heat; all matter becomes inert and incapable of reaction at that temperature. Cold does not exist. We have created this word to describe how we feel if we have too little heat.
The student continued. "Professor, does darkness exist?"
The professor responded, "Of course it does".
The student replied, "Once again you are wrong sir, darkness does not exist either. Darkness is in reality the absence of light. Light we can study, but not darkness. In fact we can use Newton's prism to break white light into many colors and study the various wavelengths of each color. You cannot measure darkness. A simple ray of light can break into a world of darkness and illuminate it. How can you know how dark a certain space is? You measure the amount of light present. Isn't this correct? Darkness is a term used by man to describe what happens when there is no light present."
Finally the young man asked the professor. "Sir, does evil exist?"
Now uncertain, the professor responded, "Of course as I have already said. We see it every day. It is in the daily example of man's inhumanity to man. It is in the multitude of crime and violence everywhere in the world. "These manifestations are nothing else but evil."
To this the student replied, "Evil does not exist sir, or at least it does not exist unto itself. Evil is simply the absence of God. It is just like darkness and cold, a word that man has created to describe the absence of God. God did not create evil. Evil is not like faith, or love, that exist just as does light and heat. Evil is the result of what happens when man does not have God's love present in his heart. It's like the cold that comes when there is no heat or the darkness that comes when there is no light."
The professor sat down.
The young mans name was Albert Einstein
http://van.hep.uiuc.edu/van/qa/section/Everything_Else/Philosophy/20020525122436.htm
you can become sceptic after this if you still think there is no god you probably cant read well enough
and if you ask yourself if Einstein believed in god then yes he did but he did not belilve in religion
כבר כתבו את הזה פה לפני כמה חודשים, אם אני זוכר נכון, בורג התייחס לזה כאל סיפור מונפץ... כמו גם רבים אחרים.
(בורג, בבקשה ממך, אל תכתוב עוד מגילה... האתר לא יעמוד בזה :'()
וגם אל תצטט את הקודמת
ישן ומופרך. :nono:
אלברט אינשטיין...מדהים...
אם Ghosthunter ואחרים לא יכתבו תגובות ארוכות, אז אני מבטיח לענות בקצרה. ;)
כן... ואני אלברט איינשטיין
:errrr:
הנושא הזה תמיד נמצא כאן! האאאא! שמישהו ישמיד אותו כבר!
מה הולך פה? אני עוד אתנזר מרוב צער!
ואני יתנצר
:o
אופס
נו גם אני נראה לך שאני אתנזר באמת? רק עם צ'....בלי ז'... ;)
יש אלהים! אם לא היה אלהים כבר מזמן אני הייתי ברחוב! כל פעם שהבנק התקשר והזהיר אותנו שהולכים לעכל לנו ת'דירה בדרך פלאים קרתה לאבא שלי תאונה והוא קיבל טונה פיצויים שסגרנו לנו בדיוק את המינוס. והוא כבר שבר שתי ידיים ורגל ככה!!!! בגלל ששני נהגים דרסו אותו ועוד תאונה אחת באיזה מוסך....
זה מזל מאלהים או לא?! והקטע שהתאונות האלה תמיד קרו רק כשהיינו במצב כספי קשה. והנה עכשיו עוד פעם נכנסו למצב קשה ופתאום ההורים שלי קיבלו החזר מס ענקי חד פעמי. זה נס או לא נס? גם הסיפור על איך סבא שלי הגיע לארץ מראה שיש אלהים...אבל אין לי כוח לספר אותו עכשיו.
דרך אגב Borg והשני שרבים על...מה שזה יהיה...כבר סטיתם מהנושא לגמרי...נדמה לי...הפסקתי לקרוא מה אתם כותבים מזמן ורק פה ושם אני רואה כל מיני מילים שלא אומרות לי כלום. מה אתם מסבכים הכל? אי אפשר להוכיח שיש אלהים. אבל יש. לפחות מבחינתי
אני מאוד מקווה שאתה לא רציני.
זה שאבא שלך שבר ידיים ורגליים זה נס? :s07:
זה נשמע מוזר...אבל זה נס. כי זה הציל אותנו מלגור ברחוב, ואמא שלי בן אדם חולה נפש ומאוד שברירי אם היא הייתה מגיעה לרחוב היא הייתה מתה מהר מאוד.
וחוץ מזה באותה תקופה אבא שלי היה אדם זבל...הוא הלך לזונות והתייחס חרא למשפחה והיה אלים אז הוא קיבל את מה שמגיע לו והיום הוא בן אדם טוב.
והוא גם הבריא מכל השברים נורא מהר. כל שבר לקח לו רק 4 חודשים-חצי שנה להחלים שזה מעולה יחסית לשברים שהיו לו.
הנה עכשיו דוד שלי שבר ברך והוא כנראה יהיה נכה לכל החיים. ורק איכשהו אבא שלי כבר נדרס פעמיים והוא בסדר גמור
אכן השגחה אלוהית :bash:
