MPEG 2 Renderer Problem [Probably]
Hi,
I've transcoded some DivX movies to MPEG 2 using TMPGEnc.
When I try to play the MPEG movie using BSplayer or Media Player Classic, they short the movie time length by twice. All the movie appears, and it doesn't play it more faster or slower.
When I try to use Cyberlink's PowerDVD to play the MPEG movie all works fine.
As I understand BSplayer and MPC uses system's default MPEG 2 renderer, and PowerDVD uses it's own Cyberlink's renderer.
Also I have the Premire renderer - MainConcept, and as I know it works fine too.
What can I do to watch movie on "regular" programs like BSplayer and MPC?
Windows shouldn't have it's own MPEG 2 renderer, or I'm worng?
P.S.
I use pretty clean Windows XP, I mean that I've formated some days ago, and I haven't done massive installs/changes of the codecs.
Thanks,
Izik :)
Nobody?
But OK, I think I've solved it.
I opened the DirectShow Filter Manager, scrolled down to "MPEG-2 Splitter", and downgraded it's Merit id to 00200000, so MainConcept's splitter have now a higher priority.
I hope it's the best solution.
Thanks anyway,
Izik.
