need fast help! im in tokyo (lacie dvd-rw)
i can buy here the latest internal dvd-rw from lacie 16x16 for 130$ or the external d2 for 200$
the problem is that the software and the drivers arein japanses and there is problems with the english xp.
is there any why the download all the softwares and drivers IN ENGLISH?
i can also buy the latest pioneer for 110$.
thx for the help. plz write IN ENGLISH cause i cant see hebrew!!!!!!
I THINK YOU CAN FOUND DRIVERS ON THE WEB SITE
i can donwload english drivers from the offical websie.
but wihout the software the dvd-rw is usless....
any suggestion?
can i work with nero on this dvd-rw?
if i can,i can put english drivers and then install english version of nero...
YES YOU CAN IF YOU USE LAST NERO
I THINK THE PIONER IS THE BEST
its O.K man......you can buy it......so the softwere and the drivers are in  japanses....BigDeal,
You can allways download them in english from the company website.....
anyway i suggest you to buy the latest pioneer for 110$.....goodluck :xyxthumbs:
keep update us, and if you have any qaestions you can allways ask.... :silly:
are you sue i can download them from the website in english? i dont think so...
the sofware is roxio toast 6
[glow=red,2,300]YES YOU CAN[/glow]
its doesnt mether if this nero or roxio you can instal what are you want and work
sure......there is a link in the company Website,but i am not sure is a freeware....let me check it and i will be back  :xyxthumbs:
O.K its a demo varsion of the software , :-\
but you can allways download the key from the emule..... ;D
LINK for the software:
http://www.roxio.com/en/support/toast/software_updatesv6.jhtml
:xyxthumbs:
