צורב של חבר נכשל בצריבה
יש לחבר שלי צורב DVD-+R/W. כהוא צורב על דיסקים של Silverline (למשל, אבל הוא ניסה עוד דיסקים) קבוצה של שירים (וניסינו עוד קבצים), בתוכנה כמו Nero6, הוא צורב איזה 3-2 שירים, ואז הנרו כותב Communication Failure והצריבה נכשלה ונפסקת. מהי הבעיה?
תודה מראש!! :xyxthumbs:
Communication failure
Error code:
Problem:
Solution:
Old IDE controller drivers - This is the most common cause of this error message. You must have the latest drivers for your IDE controller card to prevent it. (It´s the same for SCSI cards). Go to the website of the manufacturer of your controller card and obtain the latest drivers. Such as Intel, VIA, SIS, etc.
DMA settings - You may have DMA disabled for your CD-/DVD-ROM and recorder devices. You should enable this feature. If you have old drivers (even if you have the latest in some cases), DMA may not be properly supported, even though you can enable it. You should try with DMA disabled if you still have problems having enabled it.
Enable or disable DMA:
To enable DMA in Windows 2000/XP, simply go to your 'Control Panel --> Systems --> Hardware --> Device Manager'. Double click on the 'IDE ATA/ATAPI Controllers'. Right click on the 'Primary IDE Channel', go to 'Properties --> Advanced Settings' and change ´Transfer Mode´ to 'DMA if available'. Do the same for the secondary IDE channel.
For Windows 9x and ME, go to your 'Control Panel --> System --> Device Manager --> CD-ROM' and under the devices 'Properties --> Settings' enable or disable DMA.
Driver conflicts - You may have (or had) other CD recording software installed on your system. Their drivers can cause conflicts with our software when trying to communicate to the recorder. Please remove any other recording program you may have on your system and be sure all their drivers are removed as well.
Poor IDE cables - In many cases, with the recorders supporting UDMA, you must use 80pin IDE cables. 40pin IDE cables work with the recorder, but when it comes to the actual recording process, there may be problems. You may just have an IDE cable that is in poor condition and need to replace it, too. Or try a different connector on that IDE cable as the connector could be the cause.
CSEL - If your devices are jumpered with CSEL, your controller could be having trouble with this setting. It's best to change it, so that you have your devices jumpered as master or slave. Refer to the manual on your CD-ROM, DVD-ROM and recorder devices for how to do this.
top
