Dell U2410H Revision changes
There are only two revisions that made hardware changes were A01 and A02.
The A03/A04/A05s were given that number change due to non-hardware related changes made at the factories in those regions.
A00 to A01
Fixed Graininess/Dithering in sRGB and Adobe Modes- DisplayPort audio L/R Swap Issue- DisplayPort compatibility with XPS Studio 1640- Resolved the red tint seen when sharpness is adjusted to maximum when connected via VGA- OSD reacts slowly when DVI cable is not properly attached
A01 to A02
Improve grainy issue in video modes by modifying the sharpness table- Removed the unwanted black bar in pivot OSD- Resolved DisplayPort audio mute issue- Modify and standardize the DisplayPort power save sleep/wake scheme
קישור
http://en.community.dell.com/support-forums/peripherals/f/3529/p/19364993/19823591.aspx
תודה על העידכון, בדיוק חשבתי לקנות כזה, אבל החלטתי להמתין לדגמים החדשים ולראות ביקורות עלייהם.
Revision עדכני ליוני 2011 הוא A07, יתכן שיש כבר יותר חדש
יש גם לזיגזג
