Far Cry 2 - כל הפרטים כאן
מרץ 2008 המשחק היה אמור להשתחרר אך נדחה לסוף 2008
העלילה במשחק ההמשך לאחד ממשחקי ה FPS הטובים בכל הזמנים (לדעתי) תיקח אותנו לאפריקה המדברית
טיזר קצר שיראה לכם מקצת מהנוף במשחק
http://farcry.us.ubi.com/teaser/
תמונות :
http://farcry.us.ubi.com/screenshots.php
כאן תוכלו לראות שהחבר'ה באמת נסעו לאפריקה לקבל השראה ורעיונות למשחק
קצת על מאפייני המשחק:
OPEN WORLD
The extensive artistic research combined with the next-gen engine will allow you to explore over 50Km2 of seamlessly rendered African landscape. No game has ever provided such freedom of movement!
DUNIA ENGINE
The Dunia Engine was built specifically for Far Cry® 2 by the award-winning Ubisoft Montréal development team. It delivers the most realistic destructible environments, amazing special effects such as dynamic fire propagation and storm effects, real-time night-and-day cycle, dynamic music system, non-scripted enemy A.I. and so much more
REAL-TIME IMMERSION
Real-time story telling, systemic auto-healing, minimal in-game interface are just few of the features that will make you feel the tension of being alone against barbarous warlords that threaten thousands of innocent lives.
WEAPONS OF CHOICE
Choose from a wide range of weapons to make your way to your primary target. Meet the fight head-on with your machine-gun, go berserk with your machete or make stealth kills as a Sniper. If you feel that the atmosphere is not warm enough, light up your flamethrower and let your enemies and everything around them feel the heat.
VEHICLES
Fly, Drive, Run, slide and hover over the huge open world with your glider, trucks, cars, boats and much more.
דרישות מערכת (עדיין לא רשמיות)
Minimum requirements
CPU:
Pentium 4 3.2 Ghz, Pentium D 2.66 Ghz, AMD Athlon 64 3500+ or better
Video card:
NVIDIA 6800 or ATI X1650 or better
Shader Model 3 required
256 Mb of graphic memory
Memory: 1 GB
Media reader: DVD-ROM
Recommended
CPU:
Intel Core 2 Duo Family, AMD 64 X2 5200+, AMD Phenom or better
Video card:
NVIDIA 8600 GTS or better, ATI X1900 or better
512 Mb of graphic memory
Memory: 2 GB
Sound: 5.1 sound card recommended
http://www.videogamer.com/news/08-08-2008-9047.html
לאחר שהעלימו את הביקורת למשחק של המגזין PC Gamer UK שהעניק לו את הציון 94
לא הספקתי אפילו להתעמק בו ובכל זאת מצאתי את הביקורת המצולמת ברשת כאן:
http://www.overclock.net/pc-games/389536-pc-gamer-far-cry-2-gets.html
אז עכשיו אפשר לקרוא בנחת ולהבין איזה משחק מעולה אנחנו הולכים לקבל :xyxthumbs:
  • תגובות 586
  • צפיות 92.4k
פשש נשמע טוב
בזמן האחרון יוצאים משחקים התותחים !
פרייייצת הדררררך ! xD
חברה crytek נקנתה על ידי EA אז לפי מה שאני יודע המשחק לא מפותח על ידה
אז תבינו שfar cry 2 הוא אך ורק שם ולכן אן שום סיבה שהוא היה טוב כי far cry הראשון היה טוב
עם הוא היה טוב זה היה כי המפתחים מubi יודעים מה לעשות
פשוט אין לי מילים.
נשמע משחק מעולה והרבה יותר מעניין אותי מCRYSIS.
FARCRY לא על ידיד CRYTEK לא ניראה לי שיהיה שווה.[br]פורסם בתאריך: 19.10.2007 בשעה 11:15:50
EA ו CRYTEK ניראה לי זה מה גרום ל CRYTEK לדרדר.
תתחילו ליראות משחקים שחוזרים על עצמם כמו כל המשחקים של EA.
רק שלא נתקל עוד פעם במפלצות האלה שדי הרסו ת'קודם
עולם פתוח ריאלסטי עם גרפיקה מדהימה ועלילה טובה יצדיקו שידרוג
בסרטון מי שהציג אותו אמר שלא יהיו הפעם מפלצות והם הולכים על הריאליסטיות הגדולה ביותר.
מהסרטון אפשר להבין שהם מצליחים מאוד בזה :yelclap:
לא כ"כ הבנתי .
Ubisoft היא אחת ממפיצות המשחקים הגדולות בעולם.
זו חברה צרפתית שכבר הוכיחה בעבר שהיא שומרת על איכות יחסי.
את FAR-CRY פיתחה Crytek שנקנתה ע"י EA ופיתחה את Crysis
החברה פיתחה מנוע משומן וחייתי שנקרא CryENGINE 2 עליו מבוסס קרייסיס http://www.crytek.com/technology/cryengine-2/specifications.html
את FC2 מפתחת Ubisoft Montreal שהיא חברת בת של UBI
מי שפיתחה את Tom Clancy's Splinter Cell ואת סידרת Tom Clancy's Rainbow Six
ועוד לא מעט משחקים ובעיקר סיימה לפתח את Assassin's Creed
(גיימפליי חדש שמתרחש בעכו העתיקה- http://www.gamespot.com/video/935316/6181142/videoplayerpop )
אני בכלל חושב שהרווחנו מכל הסיפור הזה,קיבלנו שני משחקים מצופים -CRYSIS ו FAR-CRY2 מה רע?
נראה מאוד מעניין. :)
simonsix איך זה יכול להיות ש CRYTEK פיתחה את FAR CRY ועכשיו חברה אחרת לגמרי מפתחת את FAR CRY 2
ואכן נראה משחק שחבל על הזמן
זה בגלל שהזכויות על השם Far Cry נמצאות אצל Ubisoft ולכן עכשיו כשהם עובדים תחת EA הם לא יכולים להשתמש בזה.
אתם יכולים להעלות לפה את הדרישות מערכת??
בבקשה
High Requirements
CPU: E6600 Core 2 Duo
Graphics: Nvidia 8800GTS
RAM: 2GB
Hard Drive Space: 6-8GB
Optical Drive: DVD Drive
Recommended Requirements
CPU: Dual-Core CPU (Athlon X2 / Pentium D / Core 2 Duo)
Graphics: Nvidia 7800GT or ATI X1800XL Pro (SM 3.0)
RAM: 2GB+
Minimum Requirements
CPU: Athlon 64 3000+/Intel 2.8ghz
Graphics: Nvidia 6600 or ATI X1600 - Shader Model 2.0
RAM: 1GB
מקור:
http://www.farcry2forums.com/systemrequirements.php
איזה יופי המחשב שלי עומד ב- High Requirements
:xyxthumbs:
פחות או יותר דרישות כמו של CRYSIS
המידע הזה לא רישמי.
זוהי הערכה שמבוססת על ראיונות/חדשות וכו.
These are some estimated system requirements
