פורסם 2006 בספטמבר 720 שנים בבקשה:Samsung MightyDrive 2.0GBדי ממוצע.SiSoftware SandraBenchmark ResultsCombined Index : 1513 operation(s)/minEndurance Factor : 20.5512B Files Test : 1690 operation(s)/min32kB Files Test : 1671 operation(s)/min256kB Files Test : 1364 operation(s)/min2MB Files Test : 382 operation(s)/min64MB Files Test : 22 operation(s)/minResults Interpretation : Higher index values are better.Performance Test StatusRun ID : XP_RAUL on יוםחמישי 07 ספטמבר 2006 at 12:21:02Processor Affinity : NoSystem Timer : 3.6MHz512B Files TestRead Performance : 21661 operation(s)/min (11553 kB/sec, 77x)Write Performance : 682 operation(s)/min (364 kB/sec, 2x)Delete Performance : 804 operation(s)/minFile Fragments : 1.0Combined Index : 1690 operation(s)/min32kB Files TestRead Performance : 15570 operation(s)/min (8304 kB/sec, 55x)Write Performance : 692 operation(s)/min (369 kB/sec, 2x)Delete Performance : 790 operation(s)/minFile Fragments : 1.0Combined Index : 1671 operation(s)/min256kB Files TestRead Performance : 4907 operation(s)/min (20937 kB/sec, 139x)Write Performance : 620 operation(s)/min (2645 kB/sec, 17x)Delete Performance : 788 operation(s)/minFile Fragments : 1.0Combined Index : 1364 operation(s)/min2MB Files TestRead Performance : 694 operation(s)/min (23689 kB/sec, 157x)Write Performance : 185 operation(s)/min (6315 kB/sec, 42x)Delete Performance : 764 operation(s)/minFile Fragments : 1.0Combined Index : 382 operation(s)/min64MB Files TestRead Performance : 22 operation(s)/min (24030 kB/sec, 160x)Write Performance : 16 operation(s)/min (17476 kB/sec, 116x)Delete Performance : 515 operation(s)/minFile Fragments : 1.0Combined Index : 22 operation(s)/minEndurance Test StatusOperating System Disk Cache Used : NoUse Overlapped I/O : NoTest File Size : 32MBBlock Size : 512 byte(s)File Fragments : 1Endurance Benchmark BreakdownRepeated Sector ReWrite : 201 kB/sSequential Sector Write : 586 kB/sRandom Sector Write : 13 kB/sDriveTotal Size : 1.9GBFree Space : 1.9GB, 102%Cluster Size : 32kBPerformance TipsNotice 5901 : CD 1x= 150kB/s; Exercise caution when comparing measured versus published ratings.Notice 5008 : To change benchmarks, click Options.Notice 5004 : Synthetic benchmark. May not tally with 'real-life' performance.Notice 5006 : Only compare the results with ones obtained using the same version!Notice 5207 : Consider using the File System Benchmark for non-Flash devices.Notice 5900 : Endurance factor can only be used on the same type of device (SLC or MLC).Tip 11 : Use the 'Switch Chart Type' button to switch between Detailed and Combined charts.Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
פורסם 2006 בספטמבר 720 שנים PQI MrFlash U172 2GBSiSoftware SandraBenchmark ResultsCombined Index : 397 operation(s)/minEndurance Factor : 8.3512B Files Test : 452 operation(s)/min32kB Files Test : 395 operation(s)/min256kB Files Test : 471 operation(s)/min2MB Files Test : 89 operation(s)/min64MB Files Test : 4 operation(s)/minResults Interpretation : Higher index values are better.Performance Test StatusRun ID : MAIN on Thursday, September 07, 2006 at 13:38:33SMP Test : NoTotal Test Threads : 1SMT Test : NoDynamic MP/MT Load Balance : NoProcessor Affinity : No512B Files TestRead Performance : 10824 operation(s)/min (90 kB/sec, 0x)Write Performance : 145 operation(s)/min (1237 bytes/sec)Delete Performance : 1054 operation(s)/minFile Fragments : 1.0Combined Index : 452 operation(s)/min32kB Files TestRead Performance : 4982 operation(s)/min (2657 kB/sec, 15x)Write Performance : 130 operation(s)/min (69 kB/sec, 0x)Delete Performance : 1045 operation(s)/minFile Fragments : 1.0Combined Index : 395 operation(s)/min256kB Files TestRead Performance : 1687 operation(s)/min (7198 kB/sec, 40x)Write Performance : 180 operation(s)/min (768 kB/sec, 4x)Delete Performance : 1008 operation(s)/minFile Fragments : 1.0Combined Index : 471 operation(s)/min2MB Files TestRead Performance : 248 operation(s)/min (8465 kB/sec, 48x)Write Performance : 35 operation(s)/min (1195 kB/sec, 6x)Delete Performance : 745 operation(s)/minFile Fragments : 1.0Combined Index : 89 operation(s)/min64MB Files TestRead Performance : 8 operation(s)/min (8738 kB/sec, 49x)Write Performance : 2 operation(s)/min (2185 kB/sec, 12x)Delete Performance : 98 operation(s)/minFile Fragments : 1.0Combined Index : 4 operation(s)/minEndurance Test StatusOperating System Disk Cache Used : NoUse Overlapped I/O : NoTest File Size : 32MBBlock Size : 512 byte(s)File Fragments : 1Endurance Benchmark BreakdownRepeated Sector ReWrite : 38 kB/sSequential Sector Write : 35 kB/sRandom Sector Write : 3 kB/sDriveTotal Size : 982MBFree Space : 888MB, 90%Cluster Size : 4kBאני מבין שהכונן הזה הוא דיי על הפנים מבחינת ביצועים, אהה?כמה עולה הSAMSUNG?
פורסם 2006 בספטמבר 720 שנים מחבר 260 ש"ח נכון לרגע זה.אני מקווה שלא עשית לכונן שלך Optimize for quick removal?
פורסם 2006 בספטמבר 720 שנים נראה לי שכן, האם זה קשור ועד כמה זה יכול להשפיע?בכל מקרה איזה סוג של FORMAT אתה משתמש בכונן שלך?אני כרגע עם FAT32 על שלי.
פורסם 2006 בספטמבר 720 שנים מחבר אני גם עם FAT32.Optimize for Quick Removal מחסל באפר בדרך שיכול להשפיע בצורה דרסטית על הביצועים.
פורסם 2006 בספטמבר 720 שנים ניסתי אחד עם ואחד בלי ולא היה הבדל...נבדק עם SiSoftware Sandra 2007 על Sandisk Cruzer Micro 1GB U3SiSoftware SandraBenchmark ResultsCombined Index : 2346 operation(s)/minEndurance Factor : 46.3512B Files Test : 2910 operation(s)/min32kB Files Test : 2554 operation(s)/min256kB Files Test : 1442 operation(s)/min2MB Files Test : 315 operation(s)/min64MB Files Test : 11 operation(s)/minResults Interpretation : Higher index values are better.Performance Test StatusRun ID : RKPORTABLE on יום שישי 08 ספטמבר 2006 at 00:51:17Processor Affinity : NoSystem Timer : 3.6MHz512B Files TestRead Performance : 26504 operation(s)/min (7068 kB/sec, 47x)Write Performance : 1107 operation(s)/min (295 kB/sec, 1x)Delete Performance : 2006 operation(s)/minFile Fragments : 1.0Combined Index : 2910 operation(s)/min32kB Files TestRead Performance : 17896 operation(s)/min (9545 kB/sec, 63x)Write Performance : 968 operation(s)/min (516 kB/sec, 3x)Delete Performance : 2085 operation(s)/minFile Fragments : 1.0Combined Index : 2554 operation(s)/min256kB Files TestRead Performance : 3563 operation(s)/min (15202 kB/sec, 101x)Write Performance : 632 operation(s)/min (2697 kB/sec, 17x)Delete Performance : 1975 operation(s)/minFile Fragments : 1.0Combined Index : 1442 operation(s)/min2MB Files TestRead Performance : 478 operation(s)/min (16316 kB/sec, 108x)Write Performance : 160 operation(s)/min (5461 kB/sec, 36x)Delete Performance : 1993 operation(s)/minFile Fragments : 1.0Combined Index : 315 operation(s)/min64MB Files TestRead Performance : 15 operation(s)/min (16384 kB/sec, 109x)Write Performance : 6 operation(s)/min (6554 kB/sec, 43x)Delete Performance : 654 operation(s)/minFile Fragments : 2.0Combined Index : 11 operation(s)/minEndurance Test StatusOperating System Disk Cache Used : NoUse Overlapped I/O : NoTest File Size : 32MBBlock Size : 512 byte(s)File Fragments : 1Endurance Benchmark BreakdownRepeated Sector ReWrite : 279 kB/sSequential Sector Write : 272 kB/sRandom Sector Write : 4 kB/sDriveTotal Size : 377MBFree Space : 973MB, 258%Cluster Size : 16kBPerformance TipsNotice 5901 : CD 1x= 150kB/s; Exercise caution when comparing measured versus published ratings.Notice 5008 : To change benchmarks, click Options.Notice 5004 : Synthetic benchmark. May not tally with 'real-life' performance.Notice 5006 : Only compare the results with ones obtained using the same version!Notice 5207 : Consider using the File System Benchmark for non-Flash devices.Notice 5900 : Endurance factor can only be used on the same type of device (SLC or MLC).Tip 11 : Use the 'Switch Chart Type' button to switch between Detailed and Combined charts.Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
פורסם 2006 בספטמבר 720 שנים העברתי את זה לOptimize For Performance, ועדיין אני מקבל את אותם המספרים בסנדרה.
פורסם 2006 בספטמבר 2220 שנים OCZ MINI-KART 1GBSiSoftware SandraBenchmark ResultsCombined Index : 3385 operation(s)/minEndurance Factor : 12.6512B Files Test : 4672 operation(s)/min32kB Files Test : 3621 operation(s)/min256kB Files Test : 832 operation(s)/min2MB Files Test : 195 operation(s)/min64MB Files Test : 7 operation(s)/minResults Interpretation : Higher index values are better.Performance Test StatusRun ID : TAOTAO on יום שישי 22 ספטמבר 2006 at 15:20:27Processor Affinity : NoSystem Timer : 3.2GHz512B Files TestRead Performance : 24858 operation(s)/min (6629 kB/sec, 44x)Write Performance : 1874 operation(s)/min (500 kB/sec, 3x)Delete Performance : 3350 operation(s)/minFile Fragments : 1.0Combined Index : 4672 operation(s)/min32kB Files TestRead Performance : 13796 operation(s)/min (7358 kB/sec, 49x)Write Performance : 1483 operation(s)/min (791 kB/sec, 5x)Delete Performance : 3295 operation(s)/minFile Fragments : 1.0Combined Index : 3621 operation(s)/min256kB Files TestRead Performance : 2690 operation(s)/min (11477 kB/sec, 76x)Write Performance : 317 operation(s)/min (1353 kB/sec, 9x)Delete Performance : 3105 operation(s)/minFile Fragments : 1.0Combined Index : 832 operation(s)/min2MB Files TestRead Performance : 366 operation(s)/min (12493 kB/sec, 83x)Write Performance : 87 operation(s)/min (2970 kB/sec, 19x)Delete Performance : 2563 operation(s)/minFile Fragments : 1.0Combined Index : 195 operation(s)/min64MB Files TestRead Performance : 12 operation(s)/min (13107 kB/sec, 87x)Write Performance : 3 operation(s)/min (3277 kB/sec, 21x)Delete Performance : 475 operation(s)/minFile Fragments : 1.0Combined Index : 7 operation(s)/minEndurance Test StatusOperating System Disk Cache Used : NoUse Overlapped I/O : NoTest File Size : 32MBBlock Size : 512 byte(s)File Fragments : 1Endurance Benchmark BreakdownRepeated Sector ReWrite : 144 kB/sSequential Sector Write : 113 kB/sRandom Sector Write : 7 kB/sDriveTotal Size : 870MBFree Space : 980MB, 113%Cluster Size : 16kBPerformance TipsNotice 5901 : CD 1x= 150kB/s; Exercise caution when comparing measured versus published ratings.Notice 5008 : To change benchmarks, click Options.Notice 5004 : Synthetic benchmark. May not tally with 'real-life' performance.Notice 5006 : Only compare the results with ones obtained using the same version!Notice 5207 : Consider using the File System Benchmark for non-Flash devices.Notice 5900 : Endurance factor can only be used on the same type of device (SLC or MLC).Tip 11 : Use the 'Switch Chart Type' button to switch between Detailed and Combined charts.Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
פורסם 2006 באוקטובר 1620 שנים אני יכול להריץ בדיקה עם SiSoftware Sandra Pro Home v2007? והאם הכונן חייב להיות ריק?
פורסם 2006 באוקטובר 1620 שנים הנה תוצאות להארד דיסק חיצוני שחברתי hitachi 80 גיגה עם case חיצוני זה נקרא מהירות טובה?SiSoftware SandraBenchmark ResultsCombined Index : 10429 operation(s)/minEndurance Factor : 2.5512B Files Test : 14087 operation(s)/min32kB Files Test : 11084 operation(s)/min256kB Files Test : 3934 operation(s)/min2MB Files Test : 500 operation(s)/min64MB Files Test : 16 operation(s)/minResults Interpretation : Higher index values are better.Performance Test StatusRun ID : VIPER on יוםשני 16 אוקטובר 2006 at 10:36:25Processor Affinity : NoSystem Timer : 3.6MHz512B Files TestRead Performance : 39419 operation(s)/min (2628 kB/sec, 17x)Write Performance : 7172 operation(s)/min (478 kB/sec, 3x)File Fragments : 1.0Combined Index : 14087 operation(s)/min32kB Files TestRead Performance : 19145 operation(s)/min (10211 kB/sec, 68x)Write Performance : 6793 operation(s)/min (3623 kB/sec, 24x)File Fragments : 1.0Combined Index : 11084 operation(s)/min256kB Files TestRead Performance : 4557 operation(s)/min (19443 kB/sec, 129x)Write Performance : 2463 operation(s)/min (10509 kB/sec, 70x)Delete Performance : 141672 operation(s)/minFile Fragments : 1.0Combined Index : 3934 operation(s)/min2MB Files TestRead Performance : 610 operation(s)/min (20821 kB/sec, 138x)Write Performance : 394 operation(s)/min (13449 kB/sec, 89x)File Fragments : 1.0Combined Index : 500 operation(s)/min64MB Files TestRead Performance : 19 operation(s)/min (20753 kB/sec, 138x)Write Performance : 13 operation(s)/min (14199 kB/sec, 94x)File Fragments : 1.0Combined Index : 16 operation(s)/minEndurance Test StatusOperating System Disk Cache Used : NoUse Overlapped I/O : NoTest File Size : 32MBBlock Size : 512 byte(s)File Fragments : 1Endurance Benchmark BreakdownRepeated Sector ReWrite : 467 kB/sSequential Sector Write : 465 kB/sRandom Sector Write : 146 kB/sDriveTotal Size : 67GBFree Space : 75GB, 111%Cluster Size : 4kBPerformance TipsNotice 5901 : CD 1x= 150kB/s; Exercise caution when comparing measured versus published ratings.Notice 5008 : To change benchmarks, click Options.Notice 5004 : Synthetic benchmark. May not tally with 'real-life' performance.Notice 5006 : Only compare the results with ones obtained using the same version!Notice 5207 : Consider using the File System Benchmark for non-Flash devices.Notice 5900 : Endurance factor can only be used on the same type of device (SLC or MLC).Tip 11 : Use the 'Switch Chart Type' button to switch between Detailed and Combined charts.Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
