פורסם 2006 בפברואר 1320 שנים מתוך firing squad: What is HDCP?HDCP stands for High-bandwidth Digital Content Protection and is an Intel-initiated program that was developed with Silicon Image. This content protection system is mandatory for high-definition playback of HD-DVD or Blu-Ray discs. If you want to watch movies at 1980x1080, your system will need to support HDCP. If you don’t have HDCP support, you’ll only get a quarter of the resolution. A 75% loss in pixel density is a pretty big deal If you’ve just spent $1000 on a pair of Radeon X1900 XT graphics cards expecting to be able to playback HD-DVD or Blu-Ray movies at 1920x1080 resolution in the future, you’ve just wasted your money. it’s pretty shocking to see that apparently none of the shipping retail cards on the market have been built to take advantage of it People will not be able to turn on HDCP through a software patch since the HDCP keys need to be present during the manufacturing Although ATI has had “HDCP support” in their GPUs since the Radeon 8500, and NVIDIA has had “HDCP support” in their GPUs since the GeForce FX5700, it turns out that things are more complicated -- just because the GPU itself supports HDCP doesn’t mean that the graphics card can output a DVI/HDCP compliant stream. There needs to be additional support at the board level The boards themselves must be designed with an extra chip when the board is manufactured. The extra chip stores a crypto key, and you cannot retrofit an existing board after the board is produced הכתב שם בטוח שהוא שרף את הקשרים שלו עם יצרני הכרטיסים וכעת הוא לא יוכל לכתוב כתבות בנושא... http://www.firingsquad.com/hardware/ati_nvidia_hdcp_support/
פורסם 2006 בפברואר 1320 שנים מחבר גילו שכל כרטיסי המסך לא תומכים בקודק כי אין בהם את החומרה הזו. אם קנית היום כרטיס מסך ב-3500 ש"ח, עוד שנה לא תוכל להנות מכל היתרונות שblu-ray וHD-DVD יספקו - לא תוכל לראות סרטים בצפיפות גבוהה. HDCP נועד כדי להכניס כסף לאינטל (יש לה זכויות יוצרים על הקודק) HDCP יספק וידאו באיכות מדהימה. מדובר בתקן שיכנס חזק מאוד. הם פשוט רוצים שתקנה רישיון. כדי לקרוא את הקודק אתה צריך חומרה מתאימה, ועל החומרה הזו (או הפטנט) יש רישיון. עכשיו, גם nVIDIA וגם ATI מכריזים שהכרטיסים שלהם תומכים. בפועל, הGPU תומך אבל צריך להוסיף צ'יפ על הכרטיס (ליד הGPU). ATI מייצרת כרטיסים ולא סיפקה את הצ'יפ. nVIDIA מייצרת GPU ולא כרטיסים ולכן הביקורת עליה מתונה (יחסית לATI). בקיצור, הכריזו שתומכים בHDCP אבל זה חרטא.
פורסם 2006 בפברואר 1320 שנים מחבר נכון, אבל בעסה לקנות את ה7800 או את הX1900 באלפי שקלים ולא לקבל את מה שמובטח.לא היית מצטער לקנות ב3500 ש"ח כרטיס מסך ולגלות אחרי שנה שאתה לא יכול להריץ סרט בHD?מי שיש לו כסף לקנות את הכרטיסים הללו ירצה לקנות את bluray או hdDVD כשיגיעו.
