RTCW הפסיק לעבוד פתאום.
היום בערב הוא עבד, עכשיו הוא לא עולה פתאום. הוא כותב could not load openGL subsystem.
הנה הלוג:
Wolf 1.0.0 win-x86 Nov 13 2001
----- FS_Startup -----
Current search path:
C:\Program Files\Return to Castle Wolfenstein\main\sp_pak2.pk3 (232 files)
C:\Program Files\Return to Castle Wolfenstein\main\sp_pak1.pk3 (1342 files)
C:\Program Files\Return to Castle Wolfenstein\main\pak0.pk3 (4775 files)
C:\Program Files\Return to Castle Wolfenstein/main
6349 files in pk3 files
execing default.cfg
couldn't exec language.cfg
execing wolfconfig.cfg
execing autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found AMD w/ 3DNow!
Bypassing CD checks
----- Client Initialization -----
Cmd_AddCommand: map_restart already defined
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\SYSTEM\opengl32.dll' ): succeeded
...setting mode 9: 1600 1200 FS
...using colorsbits of 32
...calling CDS: failed, bad mode
...trying next higher resolution: failed, bad mode
...restoring display settings
...registered window class
...created window@3,22 (1606x1225)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...38 PFDs found
...hardware acceleration found
...PIXELFORMAT 8 selected
...creating GL context: succeeded
...making context current: succeeded
...WARNING: fullscreen unavailable in this mode
...using colorsbits of 16
...window already present, CreateWindowEx skipped
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
אני משתמש בדרייברים 29.80. האם תוכלו לעזור לי?
בתודה מראש, עדי רובין.
תתקין שוב את הדריברים ותעדכן את המשחק
