נשבר לי מכל האנשים המתקשים {ביצועי Radeon 8500 ב Doom 3}
שלא יודעים אנגלית. קארמק [glow=red, 2, 700]לא[/glow] אמר שהרדיאון יריץ את דום יותר טוב.
GameSpy: The world of video cards seems to change on a daily basis. What do you think of the current crop of cards on the market, and where do you see things heading? Are there any new cards that interest you? Where would you like to see things go?
Carmack: There are interesting things to be said about the upcoming cards, but NDAs will force me to just discuss the available cards.
In order from best to worst for Doom:
I still think that overall, the GeForce 4 Ti is the best card you can buy. It has high speed and excellent driver quality.
Based on the feature set, the Radeon 8500 should be a faster card for Doom than the GF4, because it can do the seven texture accesses that I need in a single pass, while it takes two or three passes (depending on details) on the GF4. However, in practice, the GF4 consistently runs faster due to a highly efficient implementation. For programmers, the 8500 has a much nicer fragment path than the GF4, with more general features and increased precision, but the driver quality is still quite a ways from Nvidia's, so I would be a little hesitant to use it as a primary research platform.
The GF4-MX is a very fast card for existing games, but it is less well suited to Doom, due to the lower texture unit count and the lack of vertex shaders.
On a slow CPU with all features enabled, the GF3 will be faster than the GF4-MX, because it offloads some work. On systems with CPU power to burn, the GF4 may still be faster.
The 128 bit DDR GF2 systems will be faster than the Radeon-7500 systems, again due to low level implementation details overshadowing the extra texture unit.
The slowest cards will be the 64 bit and SDR ram GF and Radeon cards, which will really not be fast enough to play the game properly unless you run at 320x240 or so.
LOL זה יגרום לכתבים פה לגרד קצת את המצח :lol: :smoke:
מקווה שהוא צודק!!!!!
יש לי את הRADEON ואין דבר שהוא לא עושה אבל הדרברים צריכים עוד קצת שיפור אבל לפחות התחילו לצאת הCATAYLST ששיפרו הרבה בעיות אבל הם צריכים עוד להשתפר!!!!
אתה לא קראת מילה ממה שהוא כתב, נכון?
roflmfao
תגיד אתה מפגר? יש לך קליטה סלקטיבית? תקרא הכל
ל-Radeon8500 יש את הפוטנציאל להריץ את DOOM3 יותר מהר, אבל בגלל שהדרברים לא ממנצלים את מלוא הכוח של הכרטיס אז הוא יריץ אותו פחות טוב מאשר GeForce4Ti.
דרך-אגב, לקאמרק אין שום הסכם עם ATi, הוא אפילו לא בקשרים איתם, אחרי שהם שלחו לו גרסת Beta של ה-Radeon8500 כאשר הוא הריץ את Doom3 מאחורי דלתות סגורות.
של הr300
של הr300
לא, אל תתקן אותי.
טווווווב.... למה שהוא ישתמש בBETA של הרדאון בE3 השנה, כשהרדאון כבר נמצא בשוק הרבה הרבה זמן. בE3, מאחורי דלתות סגורות הציגו את DOOM3 על R300
אין לך מושג על מה אתה מדבר! אני לא מדבר על E3! ממתי ב-E3 הציגו את זה מאחורי דלתות סגורות?! אתה יודע מה זה אומר מאחורי דלתות סגורות?! זה אומר רק למפתחים, כדי שהם יוכלו לבדוק באגים ומה לשפר, ב-E3 זה לא היה מאחורי דלתות סגורות! זה היה לקהל הרחב, מאחורי דלתות סגור זה ביטוי. הם נתנו לו גרסת בטא של ה-Radeon8500 בתחילת השנה הזאת או אפילו לפני כאשר הוא בדק את זה מאחורי דלתות סגורות.
נ.ב
אם אין לך מושג על מה אתה מדבר, תלמד לא לדבר(במילים יפות).
אתם שניכם סתם רבים!!!
הוא קיבל גם את הריידון 8500 וגם את הR300!!
אה?
מי אמר שלא?
הוא קבל מזמן את ה-Radeon8500 כגירסת בטא למבחן אישי שלו ועוד כמה מפתחים בחברה כדי לבדוק את DOOM3, ואת ה-R300 הוא קבל ל-E3 כדי להראות לקהל הרחב את DOOM3, רק שה-8500 Beta, מה לא מובן?
נ.ב
אני לא רב, אני מסביר.
שתינו דיברנו על דברים אחרים... אני דיברתי על E3. בE3 המשחק עצמו הוצג אך ורק מאחורי דלתות סגורות. הסרטונים והתמונות הוצגו לציבור הרחב.
ככה או ככה, שתינו מסכימים שקארמק אחלה ;) ;) ;)
המשחק לא הוצג, הוקרן סרט ממנו לעיתונאים בדלתיים סגורות. המשחק רץ ב-Medium Details על R300 בגלל בעיות טכניות.
חלק מהמשחק הוצג, בפעולה, לאנשים שנבחרו ע"י האל לחזות ביצירת המופת הזו
