MX510 או MX1000 ?
אני לפני קניה ואני מתלבט בין שני העכברים הללו. אין לי בעיית תקציב, אבל אני לא מעניין סתם לשרוף כסף.
האם ניתן לומר שה MX1000 היא קפיצת מדרגה או סתם אוויר חם ?
למשחקים - 510 ללא ספק, אין לו מתחרים!
למולטימדיה (גם למשחקים אבל פחות) MX1K
מדוע ? בגלל המשקל ? זמני התגובה ?
אני לא גיימר(משחק DOOM3 שעה בשבוע). אני פשוט רוצה את המוצר הטוב ביותר
get the MX510 since it's a better mouse practically.
Why?
You can mod it to work at 500Hz, instead of 125Hz, as the MX1000, works @ 125Hz also.
the mod won't work for cordless mice, since the transmitter will remain @ 125Hz.
the mod itself mods the USB port, which basically works @ 125Hz.
:THE GUIDE:
This only works for WindowsXP SP2.
Before you begin. It may have an affect on other usb devices, both positive and negative. So test with only the mouse connected first, then try adding the other devices and see if they work. If they don't try decreasing the samplerate, or go all the way back to the original file. But noone wants to do that, once they feel the power of 500hz
1. Locate usbport.sys in %SystemRoot%\System32\Drivers
2. Take a backup of the file, save it like usbport.BAK for instance.
3. Hexedit the file, locate this sequence of hex values: "3C 08 73 09 C6 86 0A 01", look in FAQ
if you can't find it.
(You can google for one, a lot of free hexeditors on the net. I used Hex Workshop 4.0)
4. It's found at different offsets depending on what usbport.sys version you got. non-SP/SP1/SP2
5. Replace that string with this one: "B0 04 73 09 52 8A 0A 01"
6. Save&reboot
7. Go into safemode (this is to avoid WFP), replace the patched usbport.sys in both
%SystemRoot%\System32\Drivers AND %SystemRoot%\System32\dllcache (hidden folder)
8. Reboot, and it should all work fine.
9. Back in WinXP, check samplerate, and you SHOULD notice the change. For the ones with total
blindness for such things; you will notice that sensitivity feels LOWER.
Other things: Better responsetime/less jitter/mouselag/whine from you.
And this is the 250hz patch.
500hz : "B0 02 73 09 52 8C 0A 01"
500hz should be enough for all at this point.
As you notice, the second hex value defines the milliseconds. 1000hz is the highest samplerate possible.
Since the number is set with a whole number, and the lowest whole number is 1.
למה אני צריך מוד של 500HZ ???
אני מאד מקווה שאתה צוחק, כי לפני שבועיים בערך היה דיון גדול מאד (יותר מ-5 עמ') בנושא.
תריץ חיפוש בפורום!
אני מקווה שאתה גם צוחק כי הדיון היה בעיקר על ההבדלים בין MX700 ל MX1000 אם אפשר לקרוא לזה דיון.
חוץ מזה, גם אם היה דיון כזה, מן הראוי שתפנה לדיון, תמליץ, ולא תענה בצורה בוטה ... אדון אחראי פורום - תן דוגמא
אולי גם לעשות לך מסאג' וקפה?
אני עובד אצלך או משהו?
אם אתה לא יודע להשתמש בחיפוש - זבש"ך.
אם היה לי כח וחשק לחפש - הייתי מביא לך את הדיון. מה אתה עושה סיפור?
ולמה אתה חושב שבכל תגובה אני צריך לענות עם 10 סמיילים ולקקנות (ל.ק.ק.) כלפיך (או בכלל כלפי משתמשים)?
סה"כ הפנתי אותך לחיפוש - איפה ראית תגובה בוטה? הסימן קריאה מעיד על בוטות? :nono:
