בבקשה תעזורו יש לי קודים לאיזה משחק ואני לא יודע איך להפעיל בבקשה תעזרו!
יש כאן הוראות איך להפעיל אני לא יודע אנגלית! אז תעזרו לי בבקשה להפעיל רשום כאן איך להפעיל את הקודים! תגידו לי איך להפעיל בבקשה!!
- Laserpointer (while ESP On)
Let's you see at whom someone is aiming.
###Remarks: It's not perfect at the moment. It
works nice with sos+das2. See it as an hint.
I hope to improve this in further versions, but
I don't have to much hope here ;)
Anyway - I love to use it - try it out.
- Aiming is slightly better, because of some changes
in the aiming code. Especially in far distances.
- Aiming is now able with ESP off.
- Starting the bot with SHIFT+B now.
Old Features:
- Artificial Intelligence
the bot is able to determine field of aim to
prevent sensless target jumping. Only headshots.
- Humanized Aiming
to prevent to be ´obviously a bot´ the AI is
able to give the aiming a more human look
- Targetchecker
the bot AI shoots only at viewable and
living/revivable players. No aiming at
dead bodys.
- ESP
the bot shows players and explosives in different
(changeable) colors und swaps these colors
automatically to translucent if the player is
currently not shoot-/viewable. Shows the class
of the players - even from the enemy party.
- Removeables
removes environmental stress from the map: smoke,
fog, snow, grass, rain and snow.
- Headflag
if wanted, the bot can show you an nice flag over
each player, that shows you the line of sight and
orientation of the head.
Remarks:
It´s mandatory for the aimbot to set the texture
quality to high - or it won´t work at all!!
The higher the screen resolution the better is
the aiming in far distances.
Setting (in dss config) the mouse sensitivity at
about 5 and accelleration off makes aiming nicer.
Is the sensitivity to high - aiming doesn't work
- your line of sight will just change really funny :)
### -> CHECK out the attached config.cfg - this one
works. It might help you, when you have problems to get
the bot running.
Use:
1. Extract the files into any folder you want.
2. Start the iprokka.exe
3. Answer the questions - then gdd is starting
4. Within the game use the bot that way:
SHIFT+B to show/hide the menue
B+up|down|left|right to move and change within the
features
זה לא קודים ::)..
