נו מה הולך עם הפינגים
Reply from 192.118.82.140: bytes=32 time=231ms TTL=246
Reply from 192.118.82.140: bytes=32 time=127ms TTL=246
Reply from 192.118.82.140: bytes=32 time=82ms TTL=246
Reply from 192.118.82.140: bytes=32 time=22ms TTL=246
Reply from 192.118.82.140: bytes=32 time=26ms TTL=246
Reply from 192.118.82.140: bytes=32 time=39ms TTL=246
Reply from 192.118.82.140: bytes=32 time=21ms TTL=246
Reply from 192.118.82.140: bytes=32 time=34ms TTL=246
Reply from 192.118.82.140: bytes=32 time=156ms TTL=246
Reply from 192.118.82.140: bytes=32 time=301ms TTL=246
Reply from 192.118.82.140: bytes=32 time=109ms TTL=246
Reply from 192.118.82.140: bytes=32 time=28ms TTL=246
Reply from 192.118.82.140: bytes=32 time=54ms TTL=246
Reply from 192.118.82.140: bytes=32 time=72ms TTL=246
Reply from 192.118.82.140: bytes=32 time=50ms TTL=246
Reply from 192.118.82.140: bytes=32 time=36ms TTL=246
Reply from 192.118.82.140: bytes=32 time=101ms TTL=246
Reply from 192.118.82.140: bytes=32 time=140ms TTL=246
Reply from 192.118.82.140: bytes=32 time=35ms TTL=246
Reply from 192.118.82.140: bytes=32 time=27ms TTL=246
Reply from 192.118.82.140: bytes=32 time=37ms TTL=246
Reply from 192.118.82.140: bytes=32 time=24ms TTL=246
Reply from 192.118.82.140: bytes=32 time=752ms TTL=246
Reply from 192.118.82.140: bytes=32 time=763ms TTL=246
Reply from 192.118.82.140: bytes=32 time=438ms TTL=246
Reply from 192.118.82.140: bytes=32 time=251ms TTL=246
Reply from 192.118.82.140: bytes=32 time=78ms TTL=246
Reply from 192.118.82.140: bytes=32 time=38ms TTL=246
Reply from 192.118.82.140: bytes=32 time=30ms TTL=246
Reply from 192.118.82.140: bytes=32 time=44ms TTL=246
Reply from 192.118.82.140: bytes=32 time=41ms TTL=246
Reply from 192.118.82.140: bytes=32 time=31ms TTL=246
Reply from 192.118.82.140: bytes=32 time=100ms TTL=246
Reply from 192.118.82.140: bytes=32 time=53ms TTL=246
Reply from 192.118.82.140: bytes=32 time=23ms TTL=246
Reply from 192.118.82.140: bytes=32 time=25ms TTL=246
Reply from 192.118.82.140: bytes=32 time=33ms TTL=246
Reply from 192.118.82.140: bytes=32 time=93ms TTL=246
Reply from 192.118.82.140: bytes=32 time=145ms TTL=246
Reply from 192.118.82.140: bytes=32 time=29ms TTL=246
Reply from 192.118.82.140: bytes=32 time=73ms TTL=246
Reply from 192.118.82.140: bytes=32 time=20ms TTL=246
Reply from 192.118.82.140: bytes=32 time=52ms TTL=246
Reply from 192.118.82.140: bytes=32 time=32ms TTL=246
Reply from 192.118.82.140: bytes=32 time=94ms TTL=246
Reply from 192.118.82.140: bytes=32 time=178ms TTL=246
Reply from 192.118.82.140: bytes=32 time=46ms TTL=246
Reply from 192.118.82.140: bytes=32 time=43ms TTL=246
Reply from 192.118.82.140: bytes=32 time=56ms TTL=246
Reply from 192.118.82.140: bytes=32 time=40ms TTL=246
Reply from 192.118.82.140: bytes=32 time=923ms TTL=246
Reply from 192.118.82.140: bytes=32 time=827ms TTL=246
Reply from 192.118.82.140: bytes=32 time=671ms TTL=246
Reply from 192.118.82.140: bytes=32 time=539ms TTL=246
Reply from 192.118.82.140: bytes=32 time=332ms TTL=246
Reply from 192.118.82.140: bytes=32 time=49ms TTL=246
Reply from 192.118.82.140: bytes=32 time=19ms TTL=246
תראו מה זה.. אני בבזק ותראו מה הולך פה, למה הקפיצות הללו >:(
הורדות, רדיו, תוכנות שיתוף, משהו פועל במקביל?
שום כלום פרט לרשת אלחוטית מעצבנת
זאת ההודעה הכי מעצבנת שראיתי בחיים >:(
נושא לא קשור לכלום ולמי אכפת כמה יצא לך הפינגים?! אתה חייב לפוצץ את הדף בPASTE המעפן הזה?!
אם אין לך משהו מעניין שמועיל לנושא לענות אז אל תטרח לענות בכלל.. פתחתי את הנושא בשאלה "למה הפינגים הללו", למה יש לי קפיצות, זה שזה מעצבן אותך זאת ממש בעיה שלך.
זה לא שיש לי בעיה עם השאלה שלך, היא בסדר גמור.
אבל יש צורה שמציגים דברים ויש חוקים לכתיבת הודעות. ואתה החלטת להתעלם מזה כי השאלה שלך דחופה לך יותר מדי מכדי להתייחס לדברים כאלה. זה הכל.
