all-in-one printer recommendation
I had the HP D145 for a little more than a year, until the scanner cathode died. anyway i'm looking for a replacement. what i'm looking for is a good printer/fax unit, not sure about ink/laser though. one option is to buy the same model i had, which is a bit old nowdays, for 2200 nis. the other option is to get something new. what are some good options in the range of noth 2500 and 4500 nis? thanks
