עזרה בדרייברים של nvidia
Software Partners
The Quadro product line provides excellent performance with leading professional software applications from the top software manufacturers. Below is a list of products we test and work with in-house.
Due to different certification schedules for many professional application software vendors, different revisions of Detonator 3 may have been certified. If the software vendor has certified a specific revision, it will be noted under the application name below.
If your application is not listed below or does not have a certified revision of the Detonator 3 driver, you can either use the certification candidate driver (available at left) or revert to your OEM/board vendors supported driver.
Drivers posted on nvidia.com do not carry any warranties nor support services.
הורדתי את זה מהאתר של nvidia והורדתי גם את התוכנה
מישהו יכול להסביר לי במה מדובר ?
הורדתי נם את הדרייבר האחרון של nvidia ושמעתי שניתן להמהיר דרייברים אם כן איך עושים זאת ?
help
