שיםור ביצועים ענק בדום 3!!! המדריך השלם!
כנראה ש-Id סתם רצו להגיד שהמשחק דורש ביצועים גבוהים או ש- Nvidia הכריחה אותם לעשות את זה...
This is a guarenteed way to get a MASSIVE performance increase to your game, at the expense of taking up a little more hard drive space (2 gigs approx). I went from running low quality at 800x600 to running High Quality on 1024x768. This improves load times AND framerate/details.
There is a catch! By doing this, you temporarily can't connect to pure multiplayer servers. You have been warned (I'll tell you how to revert it at the end)
After installation, the Doom III Folder consists only of the doom3.exe and some .PK4 files. Those PK4 files includes the entire game (sounds, videos, textures etc.) compressed. They are normally uncompressed in mid game, which is very hard on your CPU. Lets fix this!
1. Make a copy of ALL the files in C:\Program Files\Doom 3\base. This is some big filage, but if you want to revert to MP without reinstalling you need to do it.
2. Unrar the following .pk4 files (just pretend they are .rar's and open them with winrar) into the C:\Program Files\Doom 3\base folder (each one should unrar a single folder such as textures or models):
pak000.pk4
pak001.pk4
pak002.pk4
pak003.pk4
pak004.pk4 (This one has many files, put them all in \Base and over right any that apply.
3. Now delete the files above (pak000-004) or move them to another folder for storage so you can revert to multiplayer.
When you want to revert to multiplayer, restore everything you had before and get rid of the new stuff. I'm not sure if the folder "maps" is the same or not, so make sure you back that up.
When in normal mode, you should have "maps" "savegames" "config.spec" "doomConfig.cfg" "doomkey" "game00.pk4" and "gamex86.dll", nothing else.
ALSO! If you open DoomConfig.cfg (C:\programfiles\doom3\base) in notepad and change
seta image_cacheMegs "32"
to a higher number, such as 96 or 128 you will see a big increase too. Go for it bad boys!
I know this will work great for all of you, it has for me!
(לא אני כתבתי את זה)
לא ניסיתי את זה אבל שמעתי מהרבה אנשים שזה מגביראת הביצועים בעוד איזה 20 Fps.
רק שזה דורש הרבה מקום פנוי על ההרדיסק.
  • תגובות 31
  • צפיות 2.7k
אחי לא הבנתי מילה ממה שאמרתה
אבל תודה שאתה מודיע !
אחי הטוויק יצא לפני מלא זמן..
והuא מצויין יש לי 2.8 512ddr redeon 9800 pro
עשיתי את זה והמשחק רץ על 1024-768 high +פילטרים
הוא רץ על 35-60 fps
משום מה בשורה של הseta image_cacheMegs "" המספר שמופיע אצלי הוא 20 ולא 32
גם אצלי, אני לא חושב שזה משנה ושיניתי אצלי בכל זאת.
לא עזר לי בגרוש
או.קיי, אז ככה...
הטוויק הזה כבר מוכר לחלק מהמשתמשים.
שנית, הוא לא מביא לשום שיפור, מלבד דמיון פורה ופסיכולוגיה שחוגגת. בנוסף, זמני הטעינה התארכו (די מובן מאליו, כונן קשיח מלא וכעת, הוא צריך להתמודד עם מלאי עצום של קבצים בשלבי הטעינה), קצבי הפריימים לא השתפרו בכלל, כנ"ל גם לגבי הקירטועים מדי פעם.
הטוויק בקובץ ה .cfg לא יועיל בכלום, כל עוד לא משנים את הערך שנמצא בשורה מעל, או בשתי שורות מעל מ 0 ל 1. אך אבוי, ברגע ששומרים את השינויים, מתקבלת הודעה על כך שקובץ הריצה של המשחק ביצע פעולה לא חוקית ועליו להיסגר. הדבר אומר שצריך להחזיר את הערך ל 0, אבל אז, כביכול, לא מתבצע שום שינוי...
בשורה התחתונה, יוזמה יפה, חבל שהביצוע לוקה בכישלון מוחלט.
רוקפורד אתה בדקת את זה על המחשב שלך או שקראת במקום כלשהו שהטוויק הזה לא עוזר?
דווקא יצא טוויק אחד פעם לדום 3 אלפא ובטא
שאומר להוריד את ה-seta_shadows או משהו כזה (לא זוכר בדיוק) מ1-0
וזה באמת עזר לי בצורה רצינית!
בדקתי את זה אצלי וזה לא הביא לשום שיפור, דווקא לירידה.
הנה הלכה חצי שעה שלעולם לא תחזור ::)
בדקתי את זה על המחשב שלי.
לוגית, החלק של שינוי הערכים בקובץ ה .cfg לא ממש אמור לתפקד ברגע שהבחנתי שממעל, יש שורה ששולטת (בדיפולט, היא על 0) על אפשור הקצאת כמות הזכרון שאותה אנו נדרשים לשנות (לפי הטוויק).
תנסו לשנות את את מה שאמרתי משהו בקשר לצללים זה משחרר את כל המשחק ב-100%
אבל פוגע באיכות התמונה, דרסטית... מה עשינו בזה?! ::)
פשוט תגיד לשים את ההגדרות על LOW ואת הרזולוציה על 320x200 ובזה גמרנו את הסיפור.
המשחק רץ אצלי כרגע על high עם רזולוציה 1024 על 768
aa ו af
off
45-60 fps
p4 2.4c
gigacube radeon 9800np 128MB
256X2 dual cahnnel geil GD
וזה עם גרסא יחסית ישנה של קאטאליסט... נראה לי כל הרעש סביב הדרישות חומרה של המשחק הזה היה סתם...
הצעתי את זה לאנשים שרוצים לשחק במשחק בכל מחיר
לא חייב לתקוף.
