low volume from a heaset connected to computer sound card
[ltr]my friend has a headset of "Numark". while they are connected to the headphones connection (front speakers) of the computer sound card (simple Realtek AC'97), the volume is very low. but, when they are connected to a MP3 player, the volume is very high.
I've already checked the volumes on Play Control, and everything is alright there.
I also wanted to ask if with Sennheiser HD280Pro I might have the same problem (Sound Blaster Live)?[/ltr]
אצלי הם עבדו מעולה עם הכרטיס און בורד וגם עם האודגי 2.
לא אמור להיות בעיה בכלל! רק תגדיר יציאת אוזניות כדי שהכרטיס יגביר את היציאה.
[ltr]what do you mean by that? (set headphones connection)[/ltr]
[ltr]I can't edit my message.. don't know why.
anyway, if you mean to Control Panel > Sound and Audio Devices > Advanced > Stereo Headphones, I've already done it, it helped but still it's not on full volume, and bass is very low.[/ltr]
