buying a CPU,motherboard, and memorys
hello everybody.
im looking to buy a new CPU, motherboard and memorys, and i have no idea on what to pick.
im willing to spend about 2500-3000 nis on this, 3500 if you think it will really improve the options.CPU must be an amd A64, i do not OC
thank you in advance  :)
edit: oh and i need 512 mb of RAM , 1 stick or 2 is for you to decide
Excellent budjet excellent rig! Thats all i have to say!
   Samsung 512MB DDR 400 Original      680 Nis
   Albatron K8X800 ProII      869 Nis
   AMD ATHLON 64 3000+ BOX      1,360 Nis
Subtotlal:      2,910 Nis
Ok the rig was bulit in Pandas , The CPU is excellent and not so expenssive.
The mobo is great with an amazing OB sound card (7.1 channels
And the memory is avrage , not too expenssive and can be use for a little OCing.
כמות. מוצרים סה"כ
1 AMD ATHLON 64 3000+ BOX 1,360 ש"ח
1 Gigabyte GA-K8NS nForce3 250 581 ש"ח
2 OCZ 512MB DDR PC3200 400mhz Premier Series 1,381 ש"ח
סה"כ 3,322 ש"ח
from www.pandas.co.il
this is way better
1GB memory improves performance
He said that he is not OCing! so the memories is a waist of money, also he asked for half giga !
The Albatron mobo is better cause if you dont OCing, the Albatron will be suitable with a great sound card, he is the better choise, for my opnion.
thats right he asked for 512mb but he said he might invest upto 3500 if its worth it
oc'ing got nothing to do with 1GB memory 1GB memory gives a major performance boost
Ok, so 1 GB on memory , but why OCZ ?! he dont need OCing.
The mobo is steel better if he dont OCing the sound card worth it very much!
ok first of all i wanne thank the both of you :)
ok so is there an agreement on the mobo?
which should i get?
and about the memory's
if the 1 GB doesnt make the rig go any higher then 3500 than what the hell ;D
by the way, im planning to buy all of this in about 2-3 weeks, is there anything new coming out in that time period that would make you want to change what you told me?
The UnKnown - OCZ is a memory manufacture they manufacture regular and oc memory the memory i puted isnt extactly an overclockers dream
Demon-Hunter - 1GB memory will give major performance boost+heavy games will run smooth if you have a strong graphic card
if your planning buying in 2-3 weeks than ask again when the time comes things might change by then
my current Graphic card is a herculas AIW 9800 pro
so im not looking to upgrade that in a while  :)
oh and i already have a none builtin sound card the soundblaster audigy platinum so sound card is taken care of already :)
