2 Gameport 2 Joysticks 2 Problems
[ltr]I have an M$ sidewinder joystick (non-FF) and an M$ sidewinder FF wheel, both the gameport (15 pin D type) version. now I have an O/B AC97 and a Creative Live.
the first problem is that I can't have both the joystick and the wheel connected at the same time, windows doesn't add the second device that's connected, but it does show in the hardware maneger (see pic).
the second problem, which is a bit less important is that I don't have the static resistance and return to center force feedback that windows creates on the creative gameport.
Clipboard01.png[/ltr]
ניסית אולי להתקין את ההתקן שלו מחדש?
נסה מתאם לUSB ותחבר אחד אם המתאם
[ltr]the drivers come with the windows and I'm not going to spend about 200 nis for an adaptor that I don't know if it will work.[/ltr]
it doesnt cost that much ,98nis at pch
