עזרה || למבינים בלבד...Laptop Alienware
אני קונה השבוע לפטופ לצרכי גימינג כבדים, הרכבתי אותי בעצמי באתר של DELL רק רוצה לוודא שהכל לדעתכם נראה בסדר ושאין מעבד חלש מידי או כרטיס מסך חלש מידי
Alienware - R4 17.3" Laptop - Intel Core i7 - 32GB Memory - NVIDIA GeForce GTX 1080 - 256GB Solid State Drive + 1TB Hard Drive - Silver
2560X1440 QHD
תודה רבה
זה לא אומר כלום.
תן קישור כמו שצריך.
לדוגמה - איזה מעבד בדיוק ?
Windows 10 operating system
Brings back the Start Menu from Windows 7 and introduces new features, such as Edge Web browser that lets you mark up Web pages on your screen. Learn more ›
17.3" QHD display
2560 x 1440 resolution delivers amazing color and clarity.
7th Gen Intel® Core™ i7-7820HK mobile processor
Powerful quad-core, eight-way processing performance. Intel Turbo Boost technology delivers dynamic extra power when you need it, while increasing energy efficiency when you don't.
32GB system memory for intense multitasking and gaming
Abundance of high-bandwidth DDR4 RAM to smoothly run your graphics-heavy PC games and video editing applications, as well as numerous programs and browser tabs simultaneously.
1TB hard drive and 256GB solid state drive (SSD) for a blend of storage space and speed
The hard drive provides ample storage, while the SSD delivers faster start-up and data access times.
120hz G-SYNC technology for smooth gameplay
NVIDIA G-SYNC synchronizes the refresh rates between the GPU and display, eliminating screen tearing and minimizing display stutter and input lag.
Tobii eye tracking
Enables new gameplay functions for a completely unique user experience. Let your eyes be the controller and lose yourself in the game.
NVIDIA GeForce GTX 1080 graphics
Backed by 8GB GDDR5X dedicated video memory for an ultrafast, advanced GPU to fuel your games.
Windows Mixed Reality Ultra Ready
Push your gaming and VR exhilaration to the limit with Windows Mixed Reality Ultra. This PC is compatible with Windows Mixed Reality headsets.Learn more ›
Weighs 9.7 lbs. and is 1.2" thin
Compact power to go, so there's no need to compromise on visual real estate or gaming power to gain portability. 6-cell lithium-ion battery.
Bluetooth 4.1 interface syncs with compatible devices
Wirelessly transfer photos, music and other media between the desktop and your Bluetooth-enabled cell phone or MP3 player, or connect Bluetooth wireless accessories.
3 USB 3.0 ports maximize the latest high-speed devices
USB 3.0 ports are backward-compatible with USB 2.0 devices (at 2.0 speeds).
HDMI output expands your viewing options
Connect the laptop to an HDTV or high-definition monitor to set up two screens side by side or just see more of the big picture.
Thunderbolt 3 port for connecting advanced monitors and external drives
This single interface supports both high-speed data and high-definition video, plus power over cable for bus-powered devices is ideal for digital content creators.
Wireless network connectivity
High-speed wireless LAN is built into the laptop, so it connects to your network or hotspots on the most common Wi-Fi standards in both laptop and tablet modes.
Built-in FHD webcam
Makes it easy to video chat with your family and friends or teleconference with colleagues over Skype or other popular applications.
Backlit keyboard
Allows you to enjoy comfortable and accurate typing, even in dim lighting.
Basic software package included
Trial of Microsoft Office.
Additional ports
נערך על-ידי Eliav hakmon
ציטוט של Eliav hakmon
עצור !
זה מעבד דור 7.
אנחנו כבר בדור 8 !
ציטוט של askme
עצור !
זה מעבד דור 7.
אנחנו כבר בדור 8 !
כמה זה יהיה קריטי?
זה כמו לקנות רכב מודל קודם ולשאול .....
אם זה מחיר מציאה, אולי שווה לחשוב בכיוון.
אבל אתה אומר נייד כזה והא והו ובסוף מתגלה
פג תוקף ?
ציטוט של askme
פג תוקף ?
הבנתי אותך... זו אופציה מספר 2 גם באותו מחיר הבדל של 50$...הדבר היחיד שהטריד אותי זה שהדור 7 הוא QHD ושני הוא FHD
https://www.bestbuy.com/site/alienware-17-25-laptop-intel-core-i9-16gb-memory-nvidia-geforce-gtx-1080-oc-edition-1tb-hdd-512gb-solid-state-drive-black/6239400.p?skuId=6239400
שמע !
בוא תעשה הפוך.
תגיד כאן למומחים מה התקציב ותן להם
לבנות לך נייד כמו שצריך.
ולמה לקנות מבסט ביי ?
כבר הציעו לך להרכיב את המפרט באתר של דל עצמו !
ציטוט של askme
שמע !
בוא תעשה הפוך.
אני גר בארהב לא בישראל... דבר שני התקציב שלי הוא עד 3000$ והמחשב שאתה רואה כרגע זה גבול התקציב כי זה לפני מיסים\עכבר\תיק
ראשית, עד שיצתרפו המומחים, אין צורך לצטט אותי.  :)
שנית, עוד יותר טוב. מה הבעיה ?
תמלא שאלון. ע"י הקשה על המילה המודגשת ותציין בהבלטה
שאתה קונה בארה"ב וזה וזה וזה הדרישות שלך.
תאמין לי יש כאן מומחים סופר דופר לעניין !
