שוב ריסטרטים אקראיים... (BSOD)
שלום לכולם! אשמח לדעת מיועצי הBSOD מהי השגיאה בקריסות מערכת שלי. אני מצרף לכאן את התוכן DMP:
תודה לכולם!
1.
Machine Name:
Kernel base = 0xfffff802`dc412000 PsLoadedModuleList = 0xfffff802`dc7cf2f0
Debug session time: Mon May 28 10:44:05.230 2018 (UTC - 4:00)
System Uptime: 0 days 0:00:02.341
*                        Bugcheck Analysis                                    *
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: ffffb58439ec58f8, Address of the WHEA_ERROR_RECORD structure.
Arg3: 0000000000000000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000000000, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\modclass.ini, error 2
BUGCHECK_STR:  0x124_AuthenticAMD
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  WIN8_DRIVER_FAULT
PROCESS_NAME:  System
CURRENT_IRQL:  0
STACK_TEXT:
ffff840b`78dd25b0 fffff802`dc8aa901 : 00000000`00000000 ffffb584`39ec58d0 ffffb584`28873550 00000000`00000000 : nt!WheapCreateLiveTriageDump+0x7b
ffff840b`78dd2ae0 fffff802`dc6dd8e8 : ffffb584`39ec58d0 fffff802`dc51fb51 00000000`00000000 ffffb584`00000000 : nt!WheapCreateTriageDumpFromPreviousSession+0x2d
ffff840b`78dd2b10 fffff802`dc6de56b : fffff802`dc7c04e0 ffffb584`28873550 ffffb584`28873550 fffff80a`41e59b30 : nt!WheapProcessWorkQueueItem+0x48
ffff840b`78dd2b50 fffff802`dc438445 : 00000000`00000500 ffffb584`393d8040 ffffb584`28873550 ffffb584`28873550 : nt!WheapWorkQueueWorkerRoutine+0x2b
ffff840b`78dd2b80 fffff802`dc4f3ae7 : ffffb584`393d8040 00000000`00000080 ffffb584`288c5200 ffffb584`393d8040 : nt!ExpWorkerThread+0xf5
ffff840b`78dd2c10 fffff802`dc5b1bc6 : ffffcf81`e6946180 ffffb584`393d8040 fffff802`dc4f3aa0 00000003`cbec0000 : nt!PspSystemThreadStartup+0x47
ffff840b`78dd2c60 00000000`00000000 : ffff840b`78dd3000 ffff840b`78dcd000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x16
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: AuthenticAMD
IMAGE_NAME:  AuthenticAMD
DEBUG_FLR_IMAGE_TIMESTAMP:  0
FAILURE_BUCKET_ID:  X64_0x124_AuthenticAMD_PROCESSOR_BUS_PRV
Followup: MachineOwner
2.
Machine Name:
Kernel base = 0xfffff802`d861a000 PsLoadedModuleList = 0xfffff802`d89d72f0
Debug session time: Mon May 28 11:04:43.446 2018 (UTC - 4:00)
System Uptime: 0 days 0:00:02.558
Arguments:
Arg2: ffff9b09a36158f8, Address of the WHEA_ERROR_RECORD structure.
Debugging Details:
CURRENT_IRQL:  0
STACK_TEXT:
ffff9683`e404c5b0 fffff802`d8ab2901 : 00000000`00000000 ffff9b09`a36158d0 ffff9b09`920cfd20 00000000`00000000 : nt!WheapCreateLiveTriageDump+0x7b
ffff9683`e404cae0 fffff802`d88e58e8 : ffff9b09`a36158d0 fffff802`d8727b51 00000000`00000000 ffff9b09`00000000 : nt!WheapCreateTriageDumpFromPreviousSession+0x2d
ffff9683`e404cb10 fffff802`d88e656b : fffff802`d89c84e0 ffff9b09`920cfd20 ffff9b09`920cfd20 fffff802`d8c25e80 : nt!WheapProcessWorkQueueItem+0x48
ffff9683`e404cb50 fffff802`d8640445 : 00000000`00000700 ffff9b09`a3727040 fffff802`d86b9d40 ffff9b09`920cfd20 : nt!WheapWorkQueueWorkerRoutine+0x2b
ffff9683`e404cb80 fffff802`d86fbae7 : ffff9b09`a3727040 00000000`00000080 ffff9b09`920b6440 ffff9b09`a3727040 : nt!ExpWorkerThread+0xf5
ffff9683`e404cc10 fffff802`d87b9bc6 : ffff8580`81e40180 ffff9b09`a3727040 fffff802`d86fbaa0 00000000`00000000 : nt!PspSystemThreadStartup+0x47
ffff9683`e404cc60 00000000`00000000 : ffff9683`e404d000 ffff9683`e4047000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x16
STACK_COMMAND:  kb
