vga silencer and vpu recover-love from first sight?
hey all....
sorry i can't write in hebrew form because of a problem in my pc but nevermind that....
i just sleeved and installed an all new vga sulencer on a friends pc (which from now on will be names as my pc) i turned it on and it worked for 20 seconds and died, i looked around and saw that the molex wires of the uv light were not in the correct form, and they were "meshursharim" to the radron 9800pro (eeek!).
so i got the wires outt and fixed them than turned the pc on...everything worked perfectly, so i decided to counter and when i got into a map the pc stopped responding and a vpu recover error messege appeared and the pc restarted....
oh and another thing when it came up again the resulotion of the screen was changed to default, and i changed the driver to 4.5, still didn't work, i would've tried another game but i won't have any untill 3 am.....
so plz! help
לא כ"כ הבנתי, חיברת את חיבורי החשמל הפוך לכרטיס מסך?
יכול להיות ששרפת אותו :\
no man i connected the the molex of the uv cathode badly and that cable was connected to the vga...
if you read thoroughly you would have seen that the vga works but when i go to counter a vpu recover error screen appears....
that's the problem dude....
Are you sure you installed the VGA Silencer properly and that it makes proper contact with the core?, the card may be overheating very quickly and thus it crashes, also, is it VGA Silencer Rev 2.0 or Rev 3.0?
I personally have a VGA Silencer Rev 3.0 on my Radeon 9700 and it's great.
rev 3.0 i installed corretly and i have no way to know if it has a proper contact with the core as far as i know
because the silencer get's the hot air out the case is ice-cold but from what i can feel the silencer is preety hot and ut's at idle mode....
any ideas?
ok i'm gonna try another game now... ill tell you what's up afterwards....
listen up people, i got the card outand it was [glow=red,2,300]hot[/glow] abd i can see there is no contact with the gpu because of the shim...but after i demolished a radeon9800pro while taking a shim off i'm not gonna fo it again!
what can i do?
ok dudes and dudets i put another layer of as5 and it didn't do anything...
bummer right? do you believe that a format is in place?
לא הבנתי איזה פורמאט? פורמאט למחשב??? שמע אם אין לך מגע ישיר בין גוף הקירור לליבה אז זאת הבעייה שלך. אם אתה לא יודע להרכיב את הSILENCER כמו שצריך פשוט אל תעשה את זה שתתקין לך החנות שממנו קניתה, נמשע מגוחך אבל זה עדיף על כרטיס שרוף.
או סוף סוף עברית!
אני יודע להתקין בעצמי תודה ויש מגע זאת היתתה טעות שלי....
בעקבות הקצר שהיה (קראו תראד אחד או שאני יסכם פה : מולקס עם חוטים הפוכים , קצר,ריסטארט....) הכרטיס לא יכול לבצע האצה גרפית כנראה...הוא עובד בסדר בווינדוס אבל כשנכנסים למשחק הוא יוצא.....מה הולך???
נ.ב
ממש ממש דחוף!
איך מורידים משהו שדבוק למשהו עם אפוקסי????
תנסה להריץ תוכנת בנץ' כמו 3DMARK03 ותפרסם פה כמה אתה מקבל ואז נראה, לא נראה לי שהמאיץ יכול הלדפק אם כבר אז כל הכרטיס היה הולך.
איזה כרטיס זה בכלל?
אמרתי R9800PRO
ואמרתי גם שהוא נחכס למשחקים אז הוא נופל אז מן הסתם זה גם ב3DMARK...גם אם היה עובד מה הקשר בין 3DMARK לבעייה?
אמרתה שאתה חושב שהלך לך המאיץ בגלל זה אני מציע לך לבדוק את זה על תוכנת בנץ' ואל תקח את הבדיקה כמובן מאליו אולי הבעייה היא במשחק או בהגדרות של הכרטיס.
לא אחי שמתי את הכרטיס במחשב שלי וזה עשה את אותה בעייה בכמה משחקים (אני מזכיר שהכטיס לא שלי אז אל תתבלבלו...)
כדי להוריד את האפוקסי אתה צריך להקפיא את הכרטיס בתוך שקית אטומה לכמה 20-30 דקות, תכניס שטוח מתחת לתרים את הגוף קירור.
