S.T.A.L.K.E.R המדהים! צועדים לקראת E3...
For E3, we have worked on a DirectX 9 version of the game and will demonstrate cutting-edge technologies onscreen: up to 3 million polygons per frame in real time, fully dynamic lighting, soft dynamic shadows cast from every object onto other objects, as well as extensive use of shaders, post-processing effects, and more. We will demonstrate one of the in-game indoor levels--the Chernobyl sarcophagus underground areas--fully in DirectX 9. It will definitely add to the tense atmosphere, while the lighting and shadows will create an intense experience--for instance, when the shadow of a monster behind the corner appears on the wall before you can actually see the monster itself.
3 million polys per frame....damn...sweet!
Let's talk a bit about stalkers and the way they communicate. Each of the stalkers in the zone has a personal digital assistant, which he uses to contact the other stalker around. Provided the other stalker is friendly, you can invite him for communication and trade; you just send the other stalker a message after which he may either agree or refuse. If agreed, stalkers greet each other, lower weapons, and come closer. At this point, the trade window pops up on the screen. After successful trading both parties depart.
That is very original, sorta a RPG in a way...cool!
We plan to demonstrate an advanced combat AI, where the computer-controlled characters are able to orient themselves around complex levels full of diversified geometry and objects, while efficiently finding cover behind them. We also plan to reveal a new telekinetic monster, the dwarf. This guy will make good use of objects scattered around levels and throw them at you. The dwarf is truly powerful.
Wow...man, I wish I was going to E3 this year. I went to the tropics instead but crap...say it every year.
Players will get tired throughout their missions, and unless they take the opportunity to sleep--ranging from 30 minutes to several days--they run the risk of fainting. Hunger will affect players' bodies the same way; if they don't eat for a long time, they will faint and may eventually starve to death. Sleeping should take place in inconspicuous areas; however, there are no restrictions there. If encountered by a monster while sleeping, the player will automatically be woken for combat.
More realistic than I realized. Bout time. Instead of never ending stamina and running. Realism is where it is at. These guys went to Chernobyl for 2 years and completely recreated every area in detail. That is dedication and research. I anticipate this more than any other game right now.
נראה טוב ביותר!
שלוש מליון פולי לפריים? :o
צפה בטריילרים + תמונות, המשחק הזה מגדיר מחדש את המונח "מדהים". ולשם שינוי, יש לי גם הרגשה שהוא ישוחרר לקראת סוף השנה, כפי שצויין כבר מלכהתחילה.
כשכותר מסויים נטול Hype תקשורתי, החבר'ה למעלה מתפנים לעשיה איכותית.
לפי מה שנכתב הנ"ל המשחק נראה מאוד מבטיח...מישהו מוכן לתת קצת רקע על המשחק....
תודה עזרת לי מאוד
אחד המשחקים היותר מבטיחים שאמורים לצאת , אני מקווה שהוא יעשה את אותו הדבר ש FarCry
אפשר לדעת רק מה FC עשה ?? אילץ את כולנו לקנות כרטיסי מסך חדשים ?? ;)
אני ירצח מישהו אם STALKER יאלץ אותי לקנות כרטיס מסך חדש!!!
דווקא נראה לי שסטוקר, האף לייף 2 ועוד כותרים חדישים ירוצו טוב מאוד עם סידרת כרטיסי המסך החדשה של ATI.
אפשר לישון בשקט עד סוף 2004.
איזה כרטיס יש לך עכשיו?
לי יש 970פרו אני מקווה שזה יספיק :) דרך אגב ראיתי ביקורת של X800 באתר של אננ והכרטיס שלי עדיין בסדר גמור ראיתי שהוא דווקא
לא רחוק כל כך משאר הכרטיסים... כאילו יש הבדל של 30-40פריימים אבל לא נורא חח ;D
^ זו כבר הפעם ה- 700,000 שאתה אומר את אותו הרעיון באותו נוסח, כבר רואים בבירור שאתה מת לקנות X800 ואתה מודאג.
אם לא, אז הבנו כבר מה אתה רוצה להגיד.
בכל מקרה, אני שמתי עין על המשחק הזה במשך המון זמן, עוד מהמגזין PC-Gamer June2003 ;)
והדרישות של המשחק פורסמו כבר לפני די הרבה זמן, והוא לא כ''כ כבר כמו FarCry, ש- Doom3 פחות כבר ממנו.
שגיא,יש טריילרים נוספים??
מה באמת נסגר עם המשחק המיושן הזה ?
כרגע תאריך היציאה הוא 12 בדצמבר.....4097
