מצלמה דיגיטלית 2100 שקל לא "פוינט אנד שוט"
ואת http://www.megapixel.net אתם מכירים?
עוד אתר טוב עם סקירות טובות.
לידיעתך A80 זה G3 בגוף יותר קטן ועם מערך עדשות קצת שונה...
op op op , dont say it man , G3 and A80 are totally diffrent inside, not to mention the diffrence between the lenses. G3 is much more advanced inside - from the ccd to the digic proccesor , actually A80 belongs to the most basic series of canon , its a very good camera anyway , i use the a70 myself.
A80 and G3 have the same digic processor as much as I remember..
other specs are totally different though :)
זה מהאתר ש E.T הביא:
C740
Functionality 8.00
Photographic Quality: 8.60
Z1
Functionality 8.60
כנראה שאני ילך על הZ1.
אני די שמח כי הC740 ממש מכוערת לעומת הZ1 ;D
תודה E.T
Im not sure about tej same DIGIC , digic is like athlon XP - you cant say all the proccesors are the same , but for sure we can say that if the speed or if the 2 camera have exactly the same digic prosesor so all the canon camera from the last 1.5 years have the same procesor (because they all have digic) so that doesnt mean that a80 or g3 are similar ( ,any way the procesor is the last thing that effect image quality after lens and ccd that are the most important , and G3 have much better stuff of both.
C740
Functionality 8.00
Z1
Functionality 8.60
תודה E.T
Canon PowerShot A70 Reviewed May 2003
Megapixels: 3.20
Max. Resolution: 2048 x 1536 px
Our Opinion:
Functionality 8.60
Photographic Quality: 9.00
it seems they have ranked the A70 higher
note: I know very little about cameras, I just went there to see how they ranked the camera I'm thinking of buying.
כן אבל זה סוג שונה של מצלמה.
