Wolfenstein: A New Order לא מצליח להריץ על HD4870.
כאשר אני מריץ את השחק אני מקבל שגיאה של Fatal Error.
יש אשפרות לעשות ם זה משהו?
Fatal error לא אומר הרבה. מה השגיאה המדוייקת? עדיף אם תוכל להעלות צילום מסך
Wolfenstein The New Order.1683.12274 win-x64 Retail Jun 18 2014 14:27:05
------ Initializing File System ------
Current search path:
C:/Users/Michael/Saved Games/MachineGames/Wolfenstein The New Order/base/
E:/Games/Wolfenstein The New Order/base/
file system initialized.
BenchmarkGameData: ofs 0 and 0x151060480x
40 microseconds
20 microseconds
18 microseconds
19 microseconds
20 microseconds
17 microseconds
17 microseconds
18 microseconds
17 microseconds
17 microseconds
Average seek time without outliers: 18 microseconds
fileBenchmarkImpliesGameIsOnHD: true
idStreamingInstallManager::Init: using langMask 1 for lang english
1 CPU package, 4 physical cores, 4 logical cores
log file 'qconsole.log' opened on Sat Aug 16 00:30:31 2014
2667 MHz Intel CPU with MMX & SSE & SSE2 & SSE3 & SSSE3 & SSE41 & SSE42
32768 kB 1st level cache, 262144 kB 2nd level cache, 8388608 kB 3rd level cache
12272 MB System Memory
Winsock Initialized
Found interface: {B72C46BC-DC2E-4013-8DC6-2659CC3E3A08} Intel® 82578DC Gigabit Network Connection - 10.0.0.10/255.255.255.0
Sys_InitNetworking: adding loopback interface
Executing default.cfg for device #0...
execing joystick.cfg
Executing default.cfg for device #1...
Executing default.cfg for device #2...
Executing default.cfg for device #3...
idLib::SetProduction( PROD_PRODUCTION )
OpenDLCFileHandles: 0 packages mounted.
WARNING: Config file "wolfConfig.cfg" not found
Command line is: "E:\Games\Wolfenstein The New Order\WolfNewOrder_x64.exe"
providerName: Advanced Micro Devices, Inc.
driverDesc: ATI Radeon HD 4800 Series (Microsoft Corporation - WDDM v1.1)
driverVersion: 8.97.10.6
found AMD driver 8.97.10.6 (limit: 14.100.0.0)
WARNING: to old AMD driver 8.97.10.6 (limit: 14.100.0.0)
WARNING: Graphics driver warning, user choose to start anyway
------- Initializing renderSystem --------
PreliminaryRenderSetup
---registered window class
---registered fake window class
---registered context window class
GetWGLExtensionsWithFakeWindow: OpenGL Vendor: "Microsoft Corporation"
GetWGLExtensionsWithFakeWindow: OpenGL Renderer: "GDI Generic"
GetWGLExtensionsWithFakeWindow: OpenGL version: "1.1.0"
Couldn't find proc address for: wglGetExtensionsStringARB
X..WGL_EXT_swap_control not found
Couldn't find proc address for: wglSwapIntervalEXT
X..WGL_EXT_swap_control_tear not found
Couldn't find proc address for: wglGetPixelFormatAttribivARB
Couldn't find proc address for: wglGetPixelFormatAttribfvARB
Couldn't find proc address for: wglChoosePixelFormatARB
WARNING: No address, error: 487
WolfNewOrder_x64.exe @ 0x4513d9dd( ) + bytes () : ** UNKNOWN **( ** FUNC_PARAM_ERROR ** )
WolfNewOrder_x64.exe @ 0x450ca970( ) + bytes () : ** UNKNOWN **( ** FUNC_PARAM_ERROR ** )
WolfNewOrder_x64.exe @ 0x450cabcd( ) + bytes () : ** UNKNOWN **( ** FUNC_PARAM_ERROR ** )
WolfNewOrder_x64.exe @ 0x44b6d9ce( ) + bytes () : ** UNKNOWN **( ** FUNC_PARAM_ERROR ** )
WolfNewOrder_x64.exe @ 0x44b70ec5( ) + bytes () : ** UNKNOWN **( ** FUNC_PARAM_ERROR ** )
WolfNewOrder_x64.exe @ 0x44b6c78d( ) + bytes () : ** UNKNOWN **( ** FUNC_PARAM_ERROR ** )
WolfNewOrder_x64.exe @ 0x44833df5( ) + bytes () : ** UNKNOWN **( ** FUNC_PARAM_ERROR ** )
WolfNewOrder_x64.exe @ 0x44be89a0( ) + bytes () : ** UNKNOWN **( ** FUNC_PARAM_ERROR ** )
WolfNewOrder_x64.exe @ 0x45106b6f( ) + bytes () : ** UNKNOWN **( ** FUNC_PARAM_ERROR ** )
KERNEL32.DLL @ 0x88d416ad( ) + bytes () : BaseThreadInitThunk( )
ntdll.dll @ 0x891834a5( ) + bytes () : RtlUserThreadStart( )
FATAL ERROR: wglChoosePixelFormatARB not available
Dumped console text to C:\Users\Michael\Saved Games\MachineGames\Wolfenstein The New Order\base\ErrorLog_08-16-2014__12-30-35am.txt.
idRenderSystem::Shutdown()
Shutting down OpenGL subsystem
- - - תגובה אוחדה: - - -
40 microseconds
20 microseconds
18 microseconds
19 microseconds
20 microseconds
17 microseconds
17 microseconds
18 microseconds
17 microseconds
17 microseconds
Winsock Initialized
זה הדבר הראשון שקפץ לי לעין, תנסה לעדכן את הדרייבר להכי עדכני ותבדוק
זאת הבעיה, הכרטיס ישן ולא מקבל דיירברים חדשים, מה אפשר לעשות?
יש לך לפחות את דרייבר 13.9 (או 13.4 אם אתה על ווינדוס 8)
http://support.amd.com/en-us/download/desktop/legacy?product=legacy2&os=Windows%207%20-%2064
לא יודע כמה זה יעזור, אבל שווה לנסות.
בכל מקרה הכרטיס די ישן והמשחק דורש לפי מה שאני רואה כרטיס שתומך DX11 ששלך לא.
IIanF צודק אתה צריך כרטיס מסך עם DX11 בשביל המשחק הזה ול 4870 אין. עדכון דרייבר לא יעזור. יש שיטה לסמלץ DX11 אבל זה יהיה איטי מדי ולא בשביל לשחק במשחק. אם אתה באמת רוצה לשחק אותו תצטרך שידרוג לכרטיס מסך. תפנה לפורום כרטיסי מסך עם המפרט שלך ותקציב ושמחו לעזור אפילו בלהציע כרטיס יד שניה שיפעל לך
  • 5 שבועות מאוחר יותר...
היתה לי את אותה הבעיה, ה-4870 ישן מדי ולא יכול להריץ את המשחק
לכן זה היה הטריגר שגרם לי לרכוש כרטיס מסך חדש.
  • 1 חודש מאוחר יותר...
איך הצלחת לקנות את המשחק? אין בסטים ויופלאי..
Cjs-cdkeys או vpn.
כמה שזכור לי ההגבלה היא רק על אזור הקנייה
קנית מפתח לסטים? אפשר קישור למקום שאפשר לקנות מפתח? בטוחים שסטים יתקין לי את המשחק למרות שאי אפשר לקנות באיזור שלנו?
אני אישית לא קניתי את המשחק, בדרך כלל אני נמנע ממשחקים עם הגבלות מטומטמות, אבל אני יודע שיש כאן כמה משתמשים שקנו אותו, תחכה שמישהו מהם יגיב ויוודא ב 100% שהכל תקין.
אם אתה רוצה לקנות מפתח cjs-cdkeys.com נחשבת לחנות יחסית בטוחה, הרבה פה בפורום קנו ממנה מפתחות ולא היו להם בעיות.
אני קניתי בעבר מ cdkeys.com גם ללא בעיות
מפתחות לסטים, כן? אני צריך למצוא מישהו שהשתמש במפתח וזה עובד לו..
כשאני קונה זה רק מ CJS-CDKEYS
רק לקחת בחשבון שבפתיחת חשבון חדש ורכישה ראשונה צריך לעבור תהליך "אימות" שמבקשים פרטים מזהים לגביך ואחרי יום-יומיים מאשרים לך את ההזמנה ... זה רק ברכישה הראשונה
והמפתח תלוי במשחק. במקרה הזה - כן, לסטים (המשחק פועל רק דרך סטים). יהיה בדרך כלל מצויין לאיזה גרסה המפתח שנמכר
