מה הטמפרטורה המומלצת ללפטופ ?
[TABLE]
[TR]
[TD=class: ValueSpecification_dark, align: right]DELL
[/TD]
[TD=class: NameSpecification_dark]יצרן[/TD]
[/TR]
[TR]
[TD=class: ValueSpecification_light, align: right]INSPIRON 5000 17 5748 i7[/TD]
[TD=class: NameSpecification_light]דגם[/TD]
[/TR]
[TR]
[TD=class: ValueSpecification_dark, align: right]Windows 8.1 (64Bit) Hebrew[/TD]
[TD=class: NameSpecification_dark]מערכת הפעלה[/TD]
[/TR]
[TR]
[TD=class: TopicSpecification, colspan: 3, align: right] גרפיקה [/TD]
[/TR]
[TR]
[TD=class: ValueSpecification_dark, align: right]17.3 inch LED Backlit Display with Truelife and HD+ resolution (1600 x 900)[/TD]
[TD=class: NameSpecification_dark]גודל תצוגה[/TD]
[/TR]
[TR]
[TD=class: ValueSpecification_light, align: right]NVIDIA® GeForce® 840M 2GB DDR3L
[/TD]
[TD=class: NameSpecification_light]כרטיס גרפי[/TD]
[/TR]
[TR]
[TD=class: ValueSpecification_dark, align: right]YES[/TD]
[TD=class: NameSpecification_dark]מצלמת אינטרנט[/TD]
[/TR]
[TR]
[TD=class: TopicSpecification, colspan: 3, align: right] מעבד [/TD]
[/TR]
[TR]
[TD=class: ValueSpecification_dark, align: right]4th Generation Intel Core i7-4510U processor[/TD]
[TD=class: NameSpecification_dark]מעבד[/TD]
[/TR]
[TR]
[TD=class: TopicSpecification, width: 100%, colspan: 3, align: right] זיכרון [/TD]
[/TR]
[TR]
[TD=class: ValueSpecification_dark, align: right]2[/TD]
[TD=class: NameSpecification_dark]חריצי זיכרון[/TD]
[/TR]
[TR]
[TD=class: ValueSpecification_light, align: right]8GB Single Channel DDR3L 1600MHz (8GBx1)[/TD]
[TD=class: NameSpecification_light]נפח[/TD]
[/TR]
[TR]
[TD=class: TopicSpecification, width: 100%, colspan: 3, align: right] אחסון [/TD]
[/TR]
[TR]
[TD=class: ValueSpecification_dark, align: right]DVDRW[/TD]
[TD=class: NameSpecification_dark]כוננים אופטיים[/TD]
[/TR]
[TR]
[TD=class: ValueSpecification_light, align: right]1TB Serial ATA 5400RPM[/TD]
[TD=class: NameSpecification_light]גודל דיסק[/TD]
[/TR]
[/TABLE]
בדקתי בתוכנת everest ultimate dition
והינה התוצאות : זה בעבודה רגילה במחשב-(אינטרנט, שירים וכד).
וזה תמונה בז משחק כביכול שהמחשב מתאמץ...
עכשיו שתי שאלות :
1.זה בסדר הטמפרטורה של המחשב שלי בזמן מאמץ ?
2. אני לא הבנתי מזה כל הפירוט של הטמפרטורות אשמח אם תפרשו לי :)
CPU - ?
CHIPSET - ?
AUX - ?
DIMM ?
WDC ?
COOLING FANS - המהירות טובה ?
נערך על-ידי maorcohen1991
**הקפצה**
טמפ' מקסימלית למעבד שלך היא 100 מעלות.
אבל ללוח שמתחתיו/מתחת לציפסט (שנמצא על אותה צלע קירור) ממש לא. מחשב שמגיע ל 100C ייהרס
שללת משהו שלא אמרתי ולא סיפקת שום דבר שימושי...
אמרתי משהו על הצ'יפסט ? הטמפ' של הצ'יפסט חייבת להיות זהה לטמפ' של המעבד ?
אם המעבד מולחם על הלוח, ב 100C הוא פשוט יתנתק מהלוח לפניי שהוא יישרף
הציפסט והמעבד בהרבה מחשבים ניידים נמצאים על אותו heat pipe, מה שאומר שהם דיי משפיעים אחד על השני מבחינה תרמית, והטמפ' שלהם לא יהיו רחוקות אחת מהשניה. נזק ללוח באיזור של הציפסט יכול לקרות כבר באיזור של 80C ופחות מכך
אתה קצת מגזים, ראיתי ניידים שעבדו במקסימום מאמץ גם ב90-100 מעלות (ולא אחד כזה) ושום דבר לא התנק או לא שרד למשך תקופה ארוכה.
טמפ' העבודה שמה יותר גבוה מאשר נייח, כמובן שזה לא מומלץ לעבודה רציפה, אבל עדיין לא צריך להגזים לא יתפרק לו המחשב בגלל מאמץ רגעי.
נערך על-ידי taotao
- ההלחמה של המעבד היא לא הדבר היחיד שמחזיק אותו במקום.
- הלחמות אלקטרוניות נמסות ב-180-220 מעלות (תלוי בסוג, אבל לרוב זה הטווח).
- אפשרי שהצ'יפסט בכלל מקורר ע''י קירור פסיבי ולא מחובר לצינורות החום.
- עדיין אל נתת נתון אמין למאט המילה שלך.
- הניסיון מוכיח אחרת.
ציפ שמתחמם מתפשט, והמאמצים המכאניים של ההתפשטות נופלים על ההלחמות בינו ללוח. ההתפשטות משמעותית מספיק על מנת שיהיה סיכון לנזק כבר בתחום שמעל 80C. ולפעמים גם מתחת. מן הסתם הלחמות לא יישברו בטמפ' של 200+ C שבהן הן כבר לא קשיחות.....
הכוחות שמפעילה התפשטות תרמית חזקים מספיק על מנת לפגוע בהלחמה. מספיק לפגוע בנקודה אחת מתוך כמה מאות שיש מתחת לציפ BGA ממוצע על מנת שהוא לא יעבוד יותר, ואף אפוקסי (שנמצא שם על מנת להחזיק את הציפ במקום בזמן הייצור, לא בהמשך) או לחץ של מערכת קירור לא ימנעו את זה
יש ציפסטים שלא מתחממים משמעותית - בהרבה נטבוקים אין על הציפ אף מערכת קירור בכלל, ויש כאלה שכן - ומחברים אותם לצינור קירור, שבדרך כלל משותף לציפסט ולמעבד. חוצמזה, אם המעבד מולחם ללוח ולא מחובר דרך סוקט, הוא עצמו בסיכון לשבירת הלחמות גם בלי מעורבות של הציפסט
הנתון האמין הוא המחשבים שעשיתי להם reflow, כשהתקלות בהם התחילו פשוט מסתימת מערכת הקירור ועליית הטמפרטורות לאיזור ה 80C. אבל גם זה מילה שלי, אתה לא חייב לקבל אותה. המשתמשים של המחשבים האלה לא ידעו שיש בעיה בטמפרטורות שאליהן המחשב מגיע (או בכלל מה הטמפרטורות), עד שהם התחילו לקבל קפיאות וארטיפקטים - ולא מייד, אלא כשההלחמות התחילו להתעייף אחריי כמות של התפשטויות והתכווצויות
כנ"ל ואף במאמצים יותר מרגעיים.
אני פעם שכחתי את הלפטופ , פועל , סגור בתיק , בתוך רכב .
אין מילים על ההתעללות הקיצונית שהוא עבר באותן 20 דקות .
שפתחתי את התיק הבנתי שהוא פעל כל הזמן הזה , מן הרעש המטורף של המאוורר .
המחשב היה פשוט רותח . ברור מאליו שהיה מסך כחול .
ישר כיביתי אותו , ונתתי לו שעה להתקרר .
הייתי מוכן כבר לקבל שהרסתי אותו ושאני אצטרך לקנות חדש .
למזלי הרב , לא קרה כלום . והאמת הוא משמש אותי ברגעים אלה . כל זה היה לפני יותר משנה , כך שיש וודאות גבוהה שההלחמות יכולות להגיע לטמפרטורות דיי גבוהות . או שפשוט היה לי מזל .
אני מבין אבל זאת לא הנקודה פה.
מחשב מתוכנן לעבוד בתנאים מסויימים, ובסביבה מסויימת לתקופה מסויימת.
ובזמן שעליה מעל 100 מעלות למעבד זה תגרום לירידה בביצועים בצורה קיצונית (ותפגה במשתמש) - עבודה ב-70~80 מעלות היא חלק מהתכנון של המערכת.
היא נועדה מראש לעבוד כך במשך זמן מסויים (לרוב מקביל לתקופת האחריות).
השורה התחתונה שאין מה לתקן.
רק אחרי תקופת האחריות הייתי ממליץ לשפר את המערכת לאריכות חיים, אבל לא במקרה הזה- כי המחשב עושה בדיוק מה שנדרש ממנו ע''י היצרן.
- - - תגובה אוחדה: - - -
במקרה שלך חנקת אותו בתיק - הוא לא היה יכול לקרר את עצמו ובגלל זה קרס.
אין בעיה עם זה - אבל תנסה שלא לחזור על זה.
נערך על-ידי Thermalion
תקופת האחריות של מחשב נייד היא 3 שנים. זה אורך החיים שאתה מצפה לקבל ממחשב נייד ?
כן.
