דעתכם על שדרוג כ.מסך, מעבד, לוח אם וספק לטובת גיימינג במארז קיים
שלום,
ברשותי המפרט הבא -
WIN 8 Pro X64
Core I5 750 2.6GHZ
p55-US3L GIGABYTE
12GB RAM KINGSTON
ATI 6950 2GB Flushed to 6970
Power supply 550W HEC WIN
COOLER MASTER II ADVANCE
Dell 2311h
שברצוני לשדרגו ברכיבים הנ"ל -
[TABLE=width: 100%]
[TR]
[TD=class: mws_boxTop, width: 100%, align: center][/TD]
[TD]upper_right.gif[/TD]
[/TR]
[TR]
[TD=class: mws_boxLeft][/TD]
[TD] [TABLE]
[TR]
[TD=class: mws_boxCenter][TABLE=class: productListing, width: 100%]
[TR]
[TD=class: productListing-heading, align: center]Remove[/TD]
[TD=class: productListing-heading]Product(s)[/TD]
[TD=class: productListing-heading, align: center]Quantity.[/TD]
[TD=class: productListing-heading, align: right]Total[/TD]
[/TR]
[TR=class: productListing-even]
[TD=class: productListing-data, align: center]oscthumb.php?src=nODSzdPI4pzZztqdkdnd3g..&w=16&h=22&f=jpg&q=95&hash=10d9c14da1a34d113735a2d7056ca8ba[/TD]
[TD=class: productListing-data][TABLE]
[TR]
[TD=class: productListing-data, align: center]oscthumb.php?src=nODSzdPI4pzA0-DRz57W5dnR2JDS3OnKmdWYnKGsnJzfkODi2MmZz9Lh0qSXmaWT1tXxkqLZxZzZ3sadnZifmqmX2tmQndfnzA..&w=30&h=30&f=jpg&q=95&hash=683b622a59af6e7daf70a14de1d0cbc4[/TD]
[TD=class: productListing-data]Intel Core i5-4570 Processor Trey [/TD]
[/TD]
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD=class: productListing-data, align: center][/TD]
[TD=class: productListing-data, align: right]₪890[/TD]
[/TR]
[TR=class: productListing-odd]
[TR]
[TD=class: productListing-data, align: center]oscthumb.php?src=nODSzdPI4py-ztPNxejh3JSknJijzOST1tzK&w=30&h=23.9347826087&f=png&q=95&hash=877ca39bea0c12fdb2f9b8051e096157[/TD]
[TD=class: productListing-data]Gigabyte Mainboard GA-H87M-HD3 LGA 1150 [/TD]
[/TD]
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD=class: productListing-data, align: right]₪428[/TD]
[/TR]
[TR]
[TD=class: productListing-data, align: center]oscthumb.php?src=nODSzdPI4pzEuLWblaid5NjVms3f1A..&w=30&h=29.5081967213&f=jpg&q=95&hash=9fe048c4d23d99f9c0e154acfcd3e6ac[/TD]
[TD=class: productListing-data]MSI AMD Radeon R9 290 4GD5 מבצע פסח [/TD]
[/TD]
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD=class: productListing-data, align: right]₪1,899[/TD]
[/TR]
[TR]
[TD=class: productListing-data, align: center]oscthumb.php?src=nODSzdPI4py418_gzNKc3dfR0d3U39bOnZ3C2p2oxJ3LlJ3d5cw.&w=30&h=30&f=png&q=95&hash=8fc53c241ea7c2a100ad805d5c4badc3[/TD]
[TD=class: productListing-data]Arctic Freezer i11 (Sockets 115X) [/TD]
[/TD]
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD=class: productListing-data, align: right]₪135[/TD]
[/TR]
[TR]
[TD=class: productListing-data, align: center]oscthumb.php?src=nODSzdPI4pzKys3f0t3W2pTc39ji0tjU0dnWpaKn1-DLk6Cb4dXT&w=30&h=30&f=jpg&q=95&hash=e697b6619fcfc8e4b454143b0f928c35[/TD]
[TD=class: productListing-data]PSU Seasonic 650W GOLD SS-650RT [/TD]
[/TD]
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD=class: productListing-data, align: right]₪452[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD=class: mws_boxRight][/TD]
[/TR]
[/TABLE]
אשמח לדעתכם עם המפרט הנ"ל אכן ישדרג את המחשב הקיים והאם כל הרכיבים הנ"ל אכן הולכים "יד ביד" ?
כמובן שאשמח לשמוע שינויים אפשריים במפרט לטובת גיימינג בתקציב הנ"ל עם חריגה אפשרית של כמה מאות שקלים ...
יש לי פה מפרט נוסף שאשמח לדעתכם עליו -
[TABLE=width: 600]
[TR]
[TD][/TD]
[TD]מקט
[/TD]
[TD]שם מוצר
[/TD]
[TD]מחיר
[/TD]
[TD]כמות
[/TD]
[/TR]
[TR]
[TD]?ui=2&ik=93366368b7&view=att&th=1456b57516aa0a05&attid=0.1&disp=emb&zw&atsh=1
[/TD]
[TD]COREI5-4570
[/TD]
[TD]Intel Core i5-4570 4 X 3.2GHz 6MB 1333MHz LGA 1150 Box
[/TD]
[TD]969.00
[/TD]
[TD]1
[/TD]
[/TR]
[TR]
[TD]?ui=2&ik=93366368b7&view=att&th=1456b57516aa0a05&attid=0.2&disp=emb&zw&atsh=1
[/TD]
[TD]ZALMAN-CNPS10X-Optima
[/TD]
[TD]מאוורר למעבד ZALMAN CNPS10X Optima
[/TD]
[TD]169.00
[/TD]
[TD]1
[/TD]
[/TR]
[TR]
[TD]?ui=2&ik=93366368b7&view=att&th=1456b57516aa0a05&attid=0.3&disp=emb&zw&atsh=1
[/TD]
[TD]GIGABYTE-GA-H87M-HD3
[/TD]
[TD]GIGABYTE GA-H87M-HD3, Core™ i5/i7,DualDDR3 1066/1333/1600,2XPCI-E,1GB S1155
[/TD]
[TD]439.00
[/TD]
[TD]1
[/TD]
[/TR]
[TR]
[TD]?ui=2&ik=93366368b7&view=att&th=1456b57516aa0a05&attid=0.4&disp=emb&zw&atsh=1
[/TD]
[TD]GIGABYTE-Radeon-GV-R929OC-4GD
[/TD]
[TD]GIGABYTE Radeon GV-R929OC-4GD 4GB 512Bit GDDR5 OC Edition + TV OUT HDMI PCI-E
[/TD]
[TD]2,169.00
[/TD]
[TD]1
[/TD]
[/TR]
[TR]
[TD]?ui=2&ik=93366368b7&view=att&th=1456b57516aa0a05&attid=0.5&disp=emb&zw&atsh=1
[/TD]
[TD]ANTEC-EA-650D
[/TD]
[TD]ספק כח ANTEC™ Power Supply EA-650D 650W ACTIVE PFC,SATA
[/TD]
[TD]459.00
[/TD]
[TD]1
[/TD]
[/TR]
[/TABLE]
השני טיפה יותר יקר, אבל יותר זמין לי, תתעלמו מן ההפרש במחירים,
חלק מול חלק המפרט השני והראשון מקבילים ?
חיים
עקרונית הכרטיס מסך לדעתי נותן אותתיו האחרונים ומתחמם ומרעיש מאוד כשאני משחק במשחק עם רזולוציה גבוהה, ותכלס הוא עושה לי בעיות מעל חצי שנה, עם רעשים של תקתוקים לא ברורים והתחממות יתר (עבר בדיקה אצל KSP ונמצא תקין ) .
ובהנחה שאני מחליף אותו, אני כבר לא מתכוון לשדרג את המחשב שוב ב4-5 שנים הקרובות, אז את החלקים הנ"ל אני אשים במארז פשוט ואשמיש כמחשב נוסף אצל ההורים..
@haims84
1. שני המפרטים שלך לא תקינים בגלל הלוח - יש לך 12GB זיכרון. לא מוכרים מודולים של 12GB או של 6GB, כלומר בהכרח יש לך 3 מודולים (3X4GB) או 4 מודולים (2X2GB ועוד 2X1GB) (או 6 מודולים (6X2GB), אך זה לא ייתכן בלוח הנוכחי, שכן יש לו רק 4 חריצי הרחבה לזיכרון), אבל כל זה לא רלוונטי - בלוח GA-H87M-HD3 יש רק 2 חריצי הרחבה לזיכרון, כך שלא תוכן להשתמש בכל הזיכרון הקיים. אולי התכוונת ללוח H87-HD3 ולא ל H87M-HD3.
2. לא הגדרת תקציב.
3. אתה בעצם מבקש פה מפרט למחשב חדש ללא זיכרון, מארז, דיסק קשיח, כונן SSD וכונן אופטי. אני מציע שתמלא את השאלון שבסטיקי ותרשום בדיוק מה הדרישות שלך, מה התקציב ובאילו רכיבים אתה מתכוון להשתמש במחשב החדש (דגמים מדוייקים).
קודם כל תודה רבה smalul שהסבת את תשומת ליבי לעניין הלוח אם, אכן יש לי 2 סטיקים של 4GB ו2 של 2, ואכן הייתי נאלץ לוותר על 4 ג''יגה זכרון ... ממש תודה ... חסכת לי הרבה עצבים בהמשך ... אני באמת אלך על ה H87-HD3 .
הסיבה שלא מיליתי את השאלון באופן מסודר היא שאין לי באמת תקציב מוגדר, ויותר רציתי לקבל את חוות דעתכם על המפרטים שאני פרסמתי בדיוק עבור דברים לדוגמא כמו שאתה שמת לב כמו הסלוטים של הזכרונות ...
עקרונית גם הזמנתי כבר את הכרטיס מסך (MSI 290) בנפרד משאר החלקים, אז בעצם נשאר לי רק הלוח, המעבד והספק .
אם כבר אשמח לקבל תשובה על שאלה נוספת - במפרט השני המעבד שאני מזמין הוא BOX ולא TRAY, כשאם אני זוכר נכון BOX אמורים להגיע עם קירור משלהם. בהנחה שאני לא מתכוון לעשות OC למערכת, יש סיבה לקירור הנפרד או שאני יכול להוריד אותו אם אני לוקח את המפרט השני ?
נערך על-ידי haims84
1. אם אתה קונה גוף קירור למעבד, אין שום סיבה לקנות מעבד שהוא BOX - זה סתם יותר יקר.
2. מעבד בתצורת BOX אכן אמור להגיע עם גוף קירור משלו (בד"כ), ומה שניתן לומר על הקירור הזה הוא שהוא עובד. הוא לא הכי יעיל ולא הכי שקט, אבל הוא עובד. בנוסף אני אישית לא אוהב את השיטה שלהם להתקנת גוף הקירור (הלחצנים) - זה גרם לי מספיק הוצאה כספית ועצבים בכדי להמליץ על גוף קירור בעל תושבת משלו עם מנגנון התקנה אחר (בד"כ ברגים). בנוסף אני גם חושב שעדיף לקנות גוף קירור עם פלטה אחורית - זה יותר יציב ופחות מעקם את הלוח. שני הקירורים שבחרת נראים לי בסדר גמור. אני בד"כ ממליץ על ה i11 של ARCTIC, פשוט כי הוא יותר זול.
3. אם זה האתר של המארז שלך (ה CM 690 II Advanced), יש לוודא שהוא מתאים מבחינת הגודל גם לקירור למעבד (בגובה) וגם לכרטיס המסך (באורך). זה מה שכתוב באתר:
VGA card length:304mm / 11.96 inch
CPU cooler height:177mm / 6.96 inch
מבחינת הקירור למעבד - לא צריכה להיות בעיה, וגם לא מבחינת כרטיס המסך - הכרטיס של Gigabyte הוא באורך 29.4 ס"מ וכרטיס המסך של MSI הוא באורך 27.6 ס"מ (אבל זה כבר לא משנה, כי הזמנת את הכרטיס של MSI).
